Author: Subject: needing help again...
boggle
posted on 11/2/10 at 08:53 PM Reply With Quote
looks like im beaten....got my new coil and after a fiddle with the points managed to get a spark, all be it a very week one....why????
i thought a points system would be easy to prove my engine runs but it just isnt happening.... i have new cap, arm, leads and plugs....cleaned the points and set them to 0.015"....checked the timing, all is good....set the car on jump leads from my tin top to assist the battery....
turns over, my inline spark tester shows a spark, but when you take the plug out it is very week....
arrrrrgh!!!!
WHY WHY WHY WONT IT WORK!!!!
(sorry..just getting a little frustrated and cant afford an auto spark to come out and look at it)
thanks for any help with this
barry (boggle)
[Edited on 11/2/10 by boggle]
u2u me for details
doddy
posted on 11/2/10 at 08:55 PM Reply With Quote
have you earthed the engine to the chassis
Ben_Copeland
Change the points???? Not sure if you did or not.,... you can guarantee that it'll be the thing you didnt replace !
Ben
Locost Map on Google Maps
Enter Your Details Here
blakep82
i tried using spark leads to turn my engine over. smoke came out the leads, and the engine turned very slow. i guess the spark would have been weak too.
i'd try putting the battery right on properly and try again
________________________
Steve G
posted on 11/2/10 at 08:57 PM Reply With Quote
+1 on the earthing
boggle
posted on 11/2/10 at 08:59 PM Reply With Quote
i have......earth from battery to head, to block and to chassis.........
u2u me for details
Ben_Copeland
I think he was using jump leads to assist not replace the battery !
Ben
Daddylonglegs
posted on 11/2/10 at 09:01 PM Reply With Quote
Not sure if the condenser would cause a weak spark mate, worth a try?
JB
omega0684
posted on 11/2/10 at 09:02 PM Reply With Quote
just a thought...... knackered ignition module?
Daddylonglegs
posted on 11/2/10 at 09:06 PM Reply With Quote
He's running points mate, don't think there is an amp?
boggle
posted on 11/2/10 at 09:12 PM Reply With Quote
daddylonglegs...................
i could kiss you rite now!!!!!!!
ITS ALIVE!!!!!!!
THANK YOU ALL FOR YOUR INPUT.....
u2u me for details
l0rd
posted on 11/2/10 at 09:47 PM Reply With Quote
ITS ALIVE!!!!!!!
So where is the VIDEO?
Mark Allanson
posted on 11/2/10 at 09:48 PM Reply With Quote
Are you running a unballasted coil on an ballasted setup?
The coil may need 12v but is only getting 9v except when the starter is running
Daddylonglegs
posted on 11/2/10 at 10:03 PM Reply With Quote
I think I'll forgo the kiss matey, but glad I could help
boggle
posted on 11/2/10 at 10:20 PM Reply With Quote
will video it tommorow.....
sounds very loud!!!!!
mark....i dont know if the coil is ballast...it doesnt say on it..all it says ia its a 12v ford motorcraft coil part number edg 27
79bb-12024-aa
i dont have a ballast resistor fitted...it started first time when i reconnected the condensor.....
but.....
it did backfire through the carb once...
ideas???
cheers
u2u me for details
posted on 11/2/10 at 11:07 PM Reply With Quote
beatento it
ofcourse it would, not sure why you would remove it.
it serves to preven t arcing across the points plus help pump energy back into the coil.
boggle
posted on 12/2/10 at 08:35 AM Reply With Quote
i had an earthing out issue early on in the eve...when i removed it i started getting a spark....
u2u me for details
