kylerichmond
| posted on 13/2/10 at 06:45 PM |
Zetec Manifold Long Or Short
I am fitting a 2.0l xetec to my Robin Hood and i am now at the stage of choosing a manifold, i am using my DHLA 40s therfore need one to suit, after
finding some i now have a choice "Long or Short".
The long one is 100mm flange to flange
The short one is 69mm flange to flange
Which one should i go for?, will it make any difference eg more power?
big_wasa
| posted on 13/2/10 at 06:58 PM |
As long as you can get to fit. It does make a differance with weber dcoe's
kylerichmond
| posted on 14/2/10 at 01:02 PM |
Zetec Manifold
So i should go for the long one?
What sort of difference will it make oppose to the short one. How does it make a difference?
PaulBuz
| posted on 14/2/10 at 05:03 PM |
As far as I understand it, the shorter the intake length,the higher up in the rev. range the max power will be.
Longer intake will give opposite effect, but will also give better low down torque.
Paul
