Author: Subject: Damn Sump still leaking
RichardK
posted on 20/2/10 at 10:41 PM Reply With Quote
Spent all last Sunday afternoon under the bloody car, fitted the gasket properly, or so I thought, front and rear rubber seals with a bit of sealant in the corners, gasket fitted and then the sump bolts done up in the correct sequence,fresh cheapo oil, ran engine for 20 minutes idling and then retorqued the bolts. Quick blast and put it away with newspaper under the sump, checked the following evening and not a drop Today, changed the oil for the expensive stuff and oil additive and stuck on a new filter for good measure. Quick blast about 20 miles and I've noticed spots on my garage floor again.
Will be re torquing them tomorrow but does this sound normal. If the re torquing doesn't sort it, its going to the garage to get done, haven't got all the gravel out of my back yet from last week.
Normal or unusual?
I've also seen some race spec gaskets which look like they are made out of compressed paper which can be clamped tighter apparently. Any good??
Rich
Gallery updated 11/01/2011
jacko
posted on 20/2/10 at 10:45 PM Reply With Quote
You may of over tightened the bolts and cut the cork gasket
Is your sump twisted ? after welding it ?
Where is it leaking at the back could it be the crank oil seal ?
Graham
[Edited on 20/2/10 by jacko]
RichardK
posted on 20/2/10 at 10:51 PM Reply With Quote
Don't know to be honest, came inside in a strop
Don't think I did them that tight. I'll see tomorrow..
Those special gaskets here
Rich
[Edited on 20/2/10 by RichardK]
posted on 20/2/10 at 11:08 PM Reply With Quote
And theres me, he he, spotted two leaks, drained the oil, identified two pin holes, brazed them up, new sump plug and guess what? It still leaks form the same spots!!
What a laugh!
Bloody thing can wait till next winter now by jove
mookaloid
posted on 20/2/10 at 11:17 PM Reply With Quote
Feel for you there matey
Is it definitely engine oil - not gearbox oil?
RichardK
posted on 20/2/10 at 11:25 PM Reply With Quote
Yep, pretty sure as it seems to be leaking more than it did before
R
ashg
posted on 21/2/10 at 12:37 AM Reply With Quote
are you using a gasket out of a cheep motor factor kit or a proper ford one?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dhutch
posted on 21/2/10 at 01:14 AM Reply With Quote
gash!
that said, it hisses out of mine, and the dipstick, and rear axle....
bimbleuk
posted on 21/2/10 at 06:10 AM Reply With Quote
I don't have the luxury of a gasket on my Toyota engine. So I have to stick the windage plate on with sealant then the pan after that. If I do get a small leak I have simply put silicone sealant along the join and that has been enough to stop it in the past.
snapper
posted on 21/2/10 at 07:31 AM Reply With Quote
I have had leaks from the bolt holes.
Ran sealant round the bolt holes on the sump and all round the sump lip stuck the gasket on and left to set.
Cleaned the engine block sump face with spirit, dried it, coated with sealant again round the bolt holes and face and nipped up not to tight, leave to set.
Remove some bolts, coat head with sealant, nip up leave to half set, torque up.
I mad sure the crank seals were coated properly and the anoying little seal blocks were inserted properly when i fitted the rubber half moon seals. (Pinto)
Check your engine breathers, if you get sump pressure the oil will find its way out somewhere
I eat to survive
I drink to forget
DRC INDY 7
posted on 21/2/10 at 07:55 AM Reply With Quote
On the 1st pinto engine the sump gasket was cork i always seal both sides of the gasket before fitting
on the new engine i have just built i used the burtons heavy duty gasket the same as your link it is compressed paper type material that again i sealed both sides with silicone sealant then leave to set before adding oil
ps im useing a alloy sump from westfield cars
pps lots of bloody snow coming down as i type this
Puddle Dodgers Club
posted on 21/2/10 at 08:37 AM Reply With Quote
If it's any help I used the heavy duty type gasket set on my X flow engine and re used the same gasket when I rebuilt the engine, haven' had a drop leak from the sump which is going some for a Xflow.
Macbeast
posted on 21/2/10 at 09:12 AM Reply With Quote
Check first -
Is the replacement oil filter done up - sealed ?
Drain plug ditto
Are you sure it's not just spilled oil trickling down the block ?
splitrivet
posted on 21/2/10 at 09:57 AM Reply With Quote
I would have thought a cork gasket would give more compliance than a thinner paper one. Are you 100% sure it isnt off of oil seals a crack in the sump, dizzy seal or rocker cover etc and running down the engine.
Bob
RichardK
posted on 21/2/10 at 10:19 AM Reply With Quote
Really snowing here so won't be getting it outside to put up on ramps today
I'll let you know how I get on.
P.S Don't know if it was cheap one but it was from a motor factors and was about a tenner so about right in money but obviously don't know what they bought it for!
jacko
posted on 21/2/10 at 10:45 AM Reply With Quote
A daft one but you nipped the sump plug bolt ?
Snowing in Kingston upon Hull too
RichardK
posted on 21/2/10 at 10:51 AM Reply With Quote
Yes mate... But will check
Rich
RichardK
posted on 21/2/10 at 11:16 AM Reply With Quote
So what would cause the filler cap to blow off and cover everything in oil?
Going to start mopping up the mess now
austin man
posted on 21/2/10 at 12:00 PM Reply With Quote
it not the crank seal thats leaking is it ?? Have you identified a point from where the drip is comming from. We had a problem on a Zetec oil leaking from 2 points on the sump as we thought . the actual problem teurned out to be a camshaft seal and oil was making its way around the block due to airflow when moving and from the fan. Changed the cam seals and job done
RichardK
posted on 21/2/10 at 12:25 PM Reply With Quote
Schoolboy error? I filled the oil when it was on the drive, which has a slight gradient, so I could have put a little too much in it, I would have thought it would have blown the excess oil into my bottle which is nearly empty.
I've emptied the excess out which is 500ml
Mmmm, quite alot! Schoolboy error or senior moment?
Hopefully that all it was but can't take it for a run because of the snow, so laters...
On the positive side, my engine bay now looks like new
Rich
posted on 21/2/10 at 03:32 PM Reply With Quote
Excess crankcase pressure, if your lucky it could be just a blocked breather if not it may be worn piston rings bores etc
RichardK
posted on 21/2/10 at 04:43 PM Reply With Quote
I'm hoping its just because I over filled it with oil, what do we think? Possible? I checked the crankcase breather and its fine no blockage.
If bad news I'll just have to rag it until it dies then do the duratec conversion a bit earlier!
Rich
