steve8274
| posted on 1/3/10 at 10:26 PM |
bike carbs onto 1800 cvh. Help please
hi
i have a standard 1800cvh engine with existing wiring and ecu which i am using and i wish to swap from my standard carb to motorbike carbs. my
questions are
what are all the components i need?
can i continue using existing wiring loom(it isnt edis)? standard dizzy cap and coil
how difficult is it to set up once installed?
any help appreciated
thanks
steve
Steve G
| posted on 1/3/10 at 10:34 PM |
Yes you can - your ignition system is totally independant of your fueling system.
You'll need carbs (strangely), manifold (Bogg Bros or make one) air filer and blank backing plate, ideally a bike fuel pump at the back of the
car below the tank.
AdrianH
| posted on 2/3/10 at 07:41 AM |
The carb Sierra 1.8 CVH has the esc-hybrid system.
The module takes has a MAP sensor built in so you would have to have a common pipe going to that from I guess some sort of reservoir. It also has
inputs from air temp and engine temp sensors to determine the spark position.
It drives a heater in the choke circuit to enrich when cold, but I guess that could be bypassed or just not used and have a manual choke.
So I would guess if you could still incorporate the sensors it may well work.
What I do not understand is, if you get more fuel/air in the cylinder with then do you need to advance the spark or not. The esc hybrid will be set
up for the standard carb.
Adrian
[Edited on 2-3-10 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
ashg
| posted on 2/3/10 at 08:23 AM |
in my opinion bike carbs without megajolt is like a car without brakes.
Pretty Pointless.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
whitestu
| posted on 2/3/10 at 08:56 AM |
For years people have been fitting twin webbers to cars to get more power, before megajolts and the like were available, so no reason why you
won't get major beneits from fitting bike carbs with standard ignition.
Stu
steve8274
| posted on 2/3/10 at 12:23 PM |
hi
i will use something like megajolt eventually but just wanted something to start me off. (cashflow) if i leave the carb on as it is, i have to cut
bonnet for space. i want bike carbs eventually so just thought go with that straight from start to avoid un necessary hole in bonnet.
if i changed my system to edis system, would that make it easier with all connections etc.
thanks
AdrianH
| posted on 3/3/10 at 12:28 AM |
Hi Steve; sorry if teaching you to suck eggs here!
If you change over to EDIS you will have to add an external ECU such as Megajolt or Emerald or something else. I am running a 1.8CVH with the
standard carb and have thought about bike carbs, but for now I am happy with the hole in the bonnet. I think it can be done with the esc-hybrid as I
mentioned you need to add sensors to the bike carb set-up, but you would also need to to similar to Megajolt.
If my memory is correct you can use either a throttle position sensor (TPS) or manifold absolute pressure sensor (MAP) for the Megajolt. TPS is
generally easier but MAP just needs a vacuum pipe from each carb into to a small can and then a small vacuum pipe to the sensor. The small can evens
out, or gives an average pressure/vacuum to the MAP sensor.
The wiring from the esc-hybrid will not be any more complicated then for edis and megajolt and I would imagine not difficult to go between the two.
Ignoring the choke the sensors on the standard carb provide incoming air temperature, engine temp and MAP, if you go bike carbs you could stick the
air temp sensor on a mounting plate you use to mount the air filter. You would have to add the engine temp into the water system as you would loose
that from the standard inlet manifold.
Other jobs you would need to sort would be the thermostat housing and lastly the temp switch for the radiator fan, all these are normally on the inlet
manifold, but all doable else where. You would still have to solve the same issues with Megajolt.
You have to get the bike carbs set up and you would have to get the megajolt set up, generally done with use of a rolling road and a good
specialist.
Ash has fitted bike carbs to a 1600 Pinto and also used Megajolt and his experience is in this months CKC magazine, well worth a read.
Adrian
[Edited on 3-3-10 by AdrianH]
