Barksavon
posted on 2/4/10 at 07:53 AM |
Bestek Ignition
Has anyone got any comments on Bestek Distributors and electronic ignition systems, particularly on Pinto's with twin side draughts. Ta
robocog
| posted on 2/4/10 at 11:18 AM |
Megajolt and EDIS with coil pack would be the way I would do it (in fact I did)
It has plenty of scope and features and is not that expensive or difficult to setup
...unless the Bestek unit you have found is really really cheap and your not bothered about being able to map the iginition to suit your engine, set
rev limits shift lights etc
Regards
Rob
john_p_b
| posted on 2/4/10 at 11:27 AM |
had no problems with mine, fitted when i had twin 40's but i have sinse removed them and the ignition system is still just fine. fit and forget
really.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
Garyd
| posted on 2/4/10 at 11:35 AM |
Got this ignition on my x-flow and no probs since I fitted it 2 yrs ago.
Barksavon
| posted on 2/4/10 at 12:07 PM |
Rob Ive seen a lot mentioned about Megajolt but dont know much about it. Can you enlighten me any or point me in the direction of a supplier and
whether there are different types / modules etc, does it replace the standard electronic ignition module and coil etc, i am aware that i would need to
modify a dizzy to drive the oil pump....
blakep82
| posted on 2/4/10 at 12:15 PM |
have a read through this
http://www.autosportlabs.net/Megajolt_Lite_Jr.
takes a little setting up, but works really well. it's what i'm using. set up your maps on a PC while the engines running etc. set rev
limits, shift lights, advance can be controlled by either manifold pressure or throttle position. they come as DIY kits normally that you build
yourself, but there are people (on here) who will build and test them for you. i forget how much mine was, but was around the £100 mark (for the
megajolt alone) a few years back. you'll also need a trigger wheel & sensor, and fords edis 4 system from a 90s escort
________________________
bmseven
| posted on 2/4/10 at 02:54 PM |
Ditto with 40's
BMW 7 Resource
Bures Pit anyone?
