irvined
| posted on 10/4/10 at 10:14 PM |
crossflow rocker cover leaks
Hello,
I've got an alloy rocker cover on my xflow, it leaks. I've tried using the cork gasket, cork gasket with the three different types of
gasket sealer I have, and with just gasket sealant alone. It always leaks, sometimes just a drip, others a steady stream.
Its driving me slightly mad, i just can't seem to get a proper seal, what is the knack to doing this? Which gasket sealer should I use?
http://irvined.blogspot.com
Chippy
| posted on 10/4/10 at 10:53 PM |
One that stops the leak,  Cheers Ray
Fatgadget
| posted on 10/4/10 at 10:59 PM |
Evostick!
Carefully glue the gasket to the rocker cover,smear a bit of oil on the other surface.Job done.
Take care not to overtighten the screws..DON'T USE ANY SEALER!!
[Edited on 11/4/10 by Fatgadget]
prawnabie
| posted on 10/4/10 at 11:00 PM |
If you are using an alloy cover you shouldn't use the cork gasket. There is a specific paper gasket for the ally covers.
Fatgadget
| posted on 10/4/10 at 11:04 PM |
With my method you can use any type of gasket on any ally cover.
| posted on 11/4/10 at 08:14 AM |
True , it will hold the gasket in place but cork is porous and will always leak! Burtons do a better type of gasket that doesn't tend to leak
like cork, also it might be worth checking that the rocker cover gasket surface is flat on a surface plate or sheet of glass
Fatgadget
| posted on 11/4/10 at 11:00 AM |
Aye! What's wrong with a tinny winny bit of oil leaking on your chassis rails?
irvined
| posted on 11/4/10 at 05:31 PM |
I'm all for a bit of corrosion protection, but i think its a bit excessive right now
How tight is too tight for an alloy cover?
prawnabie
| posted on 11/4/10 at 07:03 PM |
The problem is it that that mating surface on the alloy rocker cover is smaller than the surface on the head. When you do the cover up it pinches the
cork gasket and doesnt seal. If you place the cork gasket on the alloy cover you can see where it doesnt match.
Fatgadget
| posted on 12/4/10 at 11:35 PM |
Its a bit like when you are making out with the missus mate!
Nah seriously.. Just feel when the bolts are pinching.And tighten them diagonally.
I had all sorts of xflows and pre-xflows ,twin cams and bdas with ally covers ..never was an issue with oil leaks...
Maybe your ally cover is warped?
