Bass1st
| posted on 17/4/10 at 04:34 PM |
Won't Start
Been out for a run in the lovely sunshine. About a mile from home my speedo and rev counter died (oil pressure, fuel and water temp OK). Car was
running fine. When I got home I turned the engine off and tried to restart it and all I get now is the sound of the solenoid and nothing else. Fuel
pump and fan running fine and battery is charged up OK. Any ideas??
Running a 16v 4age with Omex and DHLA 45's.
zilspeed
| posted on 17/4/10 at 04:37 PM |
Looks like you almsot ran out of electricity just before you got home. Now you've completely run out.
Time to get the multimeter out by the look of it.
turbodisplay
| posted on 17/4/10 at 05:02 PM |
Bad earth? I had that problem, sorted with a new earth strap to gearbox.
Darren
Bass1st
| posted on 17/4/10 at 05:07 PM |
Battery is at 5v so I think this is the problem!! Jumped the car and it fired up fine. Need to find out why the battery has gone flat... alternator is
connected OK. Trickle charger now connected.
rayward
| posted on 17/4/10 at 05:10 PM |
check what voltage your getting when the cars running.
if your alternator is working should be just over 13 volts
Ray
Bass1st
| posted on 17/4/10 at 05:20 PM |
Yes, will do.
Canada EH!
| posted on 17/4/10 at 06:00 PM |
Even a Toyota won't run without a good battery.
Canada EH!
| posted on 17/4/10 at 06:01 PM |
How are the 45's behaving?
Bass1st
| posted on 17/4/10 at 06:36 PM |
45's working very well thanks... look and sound great too.
