norfolkluego
| posted on 24/4/10 at 08:08 PM |
Calling any Megajolt experts
Thanks to your help the Luego overfuelling problem seems to be solved, ditched the Facet and Filter King and replaced them with a Fireblade fuel pump
and in line filter. Took it out for a short test and it was running great but..... there was a 'hesitation 'at 5500 rpm, can't think
of a better was of describing it. Wasn't a misfire, car just seemed to not want to push on anymore. Bought it back and had a look at the
megajolt map (can't remember where we first got it from)and noticed two thing.
We'd got the soft rev limit set to 6000 so we upped it to 7200.
There was no advance after 4500 so we upped it 2 degrees at 5500.
Took it out again and it seemed to cure the problem (although we did notice a much smaller 'hesitation' at 4500 but it did seem to drive
through that).
Are we doing the right thing or have we just lucked out.
[Edited on 24/4/10 by norfolkluego]
ashg
| posted on 24/4/10 at 08:23 PM |
how much advance do you have above 4.5k? if you advance it too much you risk blowing a hole in a piston.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
RichardK
| posted on 24/4/10 at 08:32 PM |
You running 2d or 3d? Can you attach a picture of your current map.
Maybe able to help a bit more.
Rich
Gallery updated 11/01/2011
norfolkluego
| posted on 24/4/10 at 09:02 PM |
Just waiting for Luego junior to get back in, he's got the map on his laptop, mines Vista so doesn't ******** work with MJ, as soon as
he's back I'll post up the map, thanks guys.
Norfolkluegojnr
| posted on 24/4/10 at 09:52 PM |
This is the original map, borrowed from another locoster. We're only running 2D at the mo:
mapBins=0,128,142,155,168,182,195,208,221,235
rpmBins=5,13,22,30,38,47,55,64,72,80
advance0=14,22,26,26,28,30,30,30,30,30
advance1=14,19,23,23,23,24,35,35,36,36
advance2=14,17,18,20,21,22,33,33,35,35
advance3=14,16,16,19,21,22,33,33,34,35
advance4=14,15,15,19,21,22,27,27,27,27
advance5=14,14,15,19,20,21,26,27,26,26
advance6=14,14,14,19,20,20,25,26,25,25
advance7=14,14,14,18,20,20,24,24,24,24
advance8=14,14,14,18,20,20,23,23,24,24
advance9=14,14,14,18,20,20,23,23,24,24
RichardK
| posted on 24/4/10 at 10:15 PM |
That looks like a map for map and not tps, you using a map sensor?
Rich
RichardK
| posted on 24/4/10 at 10:24 PM |
Just lifted this from another site...
#Ignition Configuration for MegaJoltLite Jr.
#Sat Nov 20 15:40:16 GMT 2004
userOutType1=1
revLimit=20
userOutType0=1
rpmBins=5,13,15,17,19,21,24,27,30,33
advance9=15,16,18,20,22,24,26,28,30,32
advance8=15,16,18,20,22,24,26,28,30,32
advance7=15,16,18,20,22,24,26,28,30,32
advance6=15,16,18,20,22,24,26,28,30,32
advance5=15,16,18,20,22,24,26,28,30,32
advance4=15,16,18,20,22,24,26,28,30,32
advance3=15,16,18,20,22,24,26,28,30,32
mapBins=20,30,50,60,100,130,150,175,200,220
advance2=15,16,18,20,22,24,26,28,30,32
advance1=15,16,18,20,22,24,26,28,30,32
advance0=15,16,18,20,22,24,26,28,30,32
cylinders=4
userOutMode3=0
userOutMode2=0
userOutMode1=0
userOutMode0=0
shiftLight=18
userOutValue3=14
userOutValue2=13
userOutValue1=12
userOutType3=1
userOutValue0=10
userOutType2=1
I'm using a pinto so can't offer you mine unfortuanatly. I'm pretty sure that when using tps the load bins go from 0 - 100 maybe
worth trying this map though.
Rich
Norfolkluegojnr
| posted on 24/4/10 at 10:28 PM |
Thanks guys.
Not using TPS or MAP at the mo, just a 2D map to get things up and running well.
THanks Richard, will try yours tomorrow.
snapper
| posted on 25/4/10 at 04:12 AM |
Map bin levels over 102 kps are for forced induction
I eat to survive
I drink to forget
karlak
| posted on 25/4/10 at 06:36 AM |
Little bit of a hijack , as I am getting my bits together for a Pinto'd megajolt. Could someone explain the difference between 2D and 3D -
What makes the difference and I am guessing a 3D is always more desireable ?
Norfolk, I came across these when looking for megajolt bits - cant vouch for them though ...
http://www.cate1.co.uk/megajolt/mapping.php
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Norfolkluegojnr
| posted on 25/4/10 at 10:17 AM |
Thanks for the help guys.
Neither of us are much good at the tuning side of things......
What is a safe upper advance limit to stick too? we want the best we can from the car, but we don't want to cause any damage!
paulf
| posted on 25/4/10 at 09:50 PM |
My maximum full load advance on a 2 litre blacktop is 26 degrees which has not caused me any problems.
Is it running in the full load state if running 2d with no load input? have you set the load columns all the same?
Paul.
