Author: Subject: Oh dear.. Pipe just burst...
scooby_doo_do
posted on 26/4/10 at 01:36 PM Reply With Quote
just had a coolant pipe burst on the c20xe westfield.. Its under the distributor and looks like a blanking pipe (my guess is it use to go to the heater matrix on the original car) - although not sure where to get another from?
Any ideas..
Craig.
Westfield 2.0 XE Redtop
MakeEverything
posted on 26/4/10 at 01:38 PM Reply With Quote
Got a photo? You may be able to make or modify a blank.
Kindest Regards,
Richard.
cd.thomson
posted on 26/4/10 at 01:39 PM Reply With Quote
hi mate,
fit a 20mm core plug
Craig
scooby_doo_do
posted on 26/4/10 at 05:17 PM Reply With Quote
thanks chaps.. i'll try to get a pic tonight..
Good thought on the core plug ;-)
cd.thomson
posted on 26/4/10 at 05:28 PM Reply With Quote
dont need a pic, i can see it in my garage .
My xe has the core plug fitted and it seems to be doing alright
Craig
iank
posted on 26/4/10 at 05:35 PM Reply With Quote
On some engines you need to connect the heater in-out connections together, with a link pipe, as the water flow relies on it, if you blank them you get hotspots.
I don't know whether the xe requires it - but I'm sure NS Dev will know the answer.
[Edited on 26/4/10 by iank]
Anonymous
blakep82
posted on 26/4/10 at 07:03 PM Reply With Quote
been told by a few folk to just balnk them off. i've got a xev right enough, but what i did was removed the front heater hose thingy, and stick a thin piece of ali plate behind it, and put it back on. the ali hose connection block thingy is needed to mount the alternator
[Edited on 26/4/10 by blakep82]
________________________
scooby_doo_do
posted on 26/4/10 at 07:36 PM Reply With Quote
here's a pic of it.. it just so happened that i was in the garage with a camera ... lol.
www.tripkings.co.uk/broke
it's a 2cm gap.. any ideas where i can get a plug from - i'm waiting for the laughs....
thanks chaps all the same for being helpfull as always.
Craig.
cd.thomson
posted on 26/4/10 at 07:50 PM Reply With Quote
http://cgi.ebay.co.uk/Quality-HD-Cup-Core-plug-20mm-787-Cadmium-Plate-x1_W0QQitemZ150418256279QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?has h=item2305a07197
Craig
scooby_doo_do
posted on 26/4/10 at 08:01 PM Reply With Quote
nice. Don't mean to sound like a complete numpty - but does that just bang in place and thats it? can't see that holding much pressure or am i wrong?
Thanks all the same ;-)
Craig
cd.thomson
posted on 26/4/10 at 08:41 PM Reply With Quote
yes its a core plug, thats what theyre designed to do.
If you look at your engine youll notice they are used along the sides of the block in exactly the same way to seal the water jacket.
put a tiny amount of sealant around the plug if you want to be doubly sure
Craig
