RichieHall
| posted on 29/4/10 at 12:42 PM |
Zetec - AP Racing clutch problems
Had a brilliant run out at Cadwell Park yesterday, but seemed to have a few teething problems with the car!
Although the biting point on the clutch appears right (about half way up) the friction plates seem to be sticking together? I have to bury the pedal
into the bulkhead to select a gear!
I'm thinking I should be able to adjust this from the pedal, but I'm not sure?
Any ideas?
Rust is lighter than Carbon Fibre!
turbodisplay
| posted on 29/4/10 at 03:07 PM |
Did you force the box in? could have bent the plate causing the clutch to keep engaged for longer.
Darren
