Stott
| posted on 30/4/10 at 11:45 AM |
Pinto top end gasket set, what are these rings for??
Anyone out there know what the 2 little rings are for in this gasket set? Pictured inside the thermostat housing gaskets here:
LINK
thanks in advance, stott
westf27
| posted on 30/4/10 at 12:01 PM |
not sure but they may be spray bar seals
555
Daddylonglegs
| posted on 30/4/10 at 12:46 PM |
Maybe for the bolt holes between faces?
nickmatt59
| posted on 30/4/10 at 01:09 PM |
They look like valve stem oil seals to me.
Hope this helps.
Nick
jollygreengiant
| posted on 30/4/10 at 01:37 PM |
Not to do with spray bar, this fits with no seals/gaskets, Not valve stem oil seals, and not to go between any gasket faces.
Tho only one that I can think of is replacement oil seal washers for the two front angled face rocker cover bolts (you know the ones that go into the
cam bearing post).
Stott
| posted on 30/4/10 at 02:09 PM |
Yeah ^^^^ 10 points, worked it out a few minutes ago, they are the rubber backed steel washers for the front rocker bolts
Stott
Daddylonglegs
| posted on 30/4/10 at 05:47 PM |
Well done that man, give him a t-shirt
mcerd1
| posted on 30/4/10 at 07:27 PM |
cam bearing post).
am I being stupid, or did mine not have these ? (EFI head)
jollygreengiant
| posted on 3/5/10 at 03:30 PM |
cam bearing post).
If its the EFI head then you should have the wide gasket and rocker cover. These rocker covers should have their own set of bolts and special load
spreading washers and again the ones for the two front holes will have an oil seal in them. But these later types of bolts and load spreading washers
are not serviced with any head gasket set that I have seen.
Hope this helps.
