Author: Subject: Type 9 issues
Marcus
posted on 5/5/10 at 08:10 PM Reply With Quote
Type 9 issues
Hi all, A fellow Locoster has fitted a type 9 to his crossflow. All good, I hear you say, but the propshaft only goes into the gearbox just over an inch, after that it gets very stiff. So stiff infact that is stops spinning and the car will not move. It sounds like the output shaft of the box is bent or similar. We tried the prop on my Type 9 and it slides in right up to the yoke so that's ok. Anyone had similar? looks like engine and box out this weekend to have a look.....
Marcus
Because kits are for girls!!
blakep82
posted on 5/5/10 at 08:13 PM Reply With Quote
take the oil seal out and see if theres anything jammed behind/inside it?
________________________
Paul TigerB6
posted on 5/5/10 at 09:10 PM Reply With Quote
Could also be the rear bearing thats allowing the output shaft to go off centre I guess
link
Not cheap - but maybe an easier option than sourcing another box if its confirmed to be the only fault. Personally i'd source another box though if there's a mechanical issue rather than just a seal
