AdrianH
| posted on 12/5/10 at 04:51 PM |
Round trip Stonleigh and back 280 ish miles I got 36 mpg.
Mostly motorway 2 in car and camping gear on back 1.8 CVH and carb.
Adrian
Why do I have to make the tools to finish the job? More time then money.
MikeRJ
| posted on 12/5/10 at 05:29 PM |
quote: Originally posted by franky
A standard m3 does 28ish so should get 35-45 pulling less than half the weight.
Aerodynamics are appalling on a 7, takes a lot of power just to push it along at 70mph.
deltron63
| posted on 12/5/10 at 05:45 PM |
1.8 zetec, bike carbs. about the same as you
hobbsy
| posted on 12/5/10 at 05:49 PM |
12.5 AFR at WOT is a bit rich unless you're running forced induction and looking to cool things down with extra fuel.
Around 13.2 to 13.4 is where I thought max power was at?
quote: Originally posted by flak monkey
Do you have a WB Lamda fitted?
If so it will tell you most of what you need to know.
You want to aim at 14.7 cruising and light acceleration. And 12.5AFR WOT. I assume you have mapped using alpha_n and not speed_density.
Upload your msq and I will have a look.
flak monkey
| posted on 12/5/10 at 05:56 PM |
Fastest burning mixture is at 12.5 and is also where max power is
Forced induction often run as low as 11 but thats extreme.
Sera
http://www.motosera.com
clairetoo
| posted on 12/5/10 at 06:14 PM |
Cruising up from Detling show the other week I got near 35mpg at around 70-75 , but hooning brings that down to under 20
Thats a 2.5 V6 in a fairly heavy Fury .
The crossflow I used to run would do high 40's at motorway speeds - a full house , 165bhp screamer on Omex and TB's
Its cuz I is blond , innit
Claire xx
Will weld for food......
Davey D
| posted on 12/5/10 at 06:32 PM |
It was a round trip of 250 miles to and from Stoneleigh. I managed to get that out of 1 tank of fuel in my R1 5vy powered VortX - 30mpg i was very
pleased with that. We was 2 up in the car too, so more weight
zilspeed
| posted on 12/5/10 at 07:07 PM |
quote: Originally posted by mookaloid
I used to get about 3-4 mpg on a hill climb day
Friend of mine used to run a Venturi LM600.
At Knockhill, it used 1 litre of fuel per lap of the track.
ditchlewis
| posted on 12/5/10 at 07:21 PM |
2.1 pinto with twin 45's i get 23mpg on the motorway and about 8mpg if i am toeing it.
you cant put a price on fun .
ditch
roadrunner
| posted on 12/5/10 at 08:08 PM |
Zx9r 345 mile round trip to Stoneleigh cost me £75, i get that to about 25mpg.
mcerd1
| posted on 12/5/10 at 08:09 PM |
Adrian
your doing well then - I only got ~32mpg on a 640 mile round trip with a 1.8 blacktop zetec....
...and that was in the tin-top
hobbsy
| posted on 12/5/10 at 08:31 PM |
11:1 sound like you're getting close to washing the bores. Or maybe that's when you're hitting single figures
I'm sure they set up my 200SX (S14a ~370bhp) up at around low 13's
AdrianH
| posted on 12/5/10 at 09:05 PM |
Adrian
The reason is the wife won't let me thrash it when she's in, so most of time 65 to 70 mph.
Adrian
mcerd1
| posted on 12/5/10 at 09:23 PM |
Adrian
Adrian
I recon I did about 200 miles of that in 3rd gear
linky
FASTdan
| posted on 13/5/10 at 09:54 AM |
single figures is bore washing territory. However low 13's is a bit risky on a turbo lump, 12.8 is as high as I'd ever like to see on my
XR2 turbo - based on advice from various tuners.
our 2.0 pinto on 40's did low 30mpg's on last years le mans trip.
The 2.3 duratec on ZX9R carbs did 37mpg going to the rolling road and back (about 120 mile round trip, cruising 50-80mph and some booting it).
Irony
| posted on 13/5/10 at 12:46 PM |
Quite a informative thread. I noticed JollyGreenGiants post with a MPG of 25. Everyone always says that Rover V8 are big, slow, heavy and terrible
on fuel. At not much heavier than a Pinto, pushing 200 BHP coupled with 25mpg it seems like a good option!
Makes me happy considering a V8's going in mine!
