Author: Subject: "Plug chop" still valid?
Fred W B
posted on 19/5/10 at 02:29 PM Reply With Quote
In my 2 stroke racing days I was used to doing a "Plug chop" to check mixture:
Get a decent length of run at full throttle.
Clutch in, cut motor, stop.
Pull spark plug/s.
Check colour.
white = too lean.
light tan = perfect
grey = too rich.
black = way too rich.
I seem to recall reading that this technique is not valid with today's Unleaded petrol, as the plugs do not colour as described above? Any experts care to comment?.
Any yes I know today we use rolling roads, laptops and sensors, but in the absence of these?
Fred W B
You can do it quickly. You can do it cheap. You can do it right. – Pick any two.
matt_gsxr
posted on 19/5/10 at 02:30 PM Reply With Quote
I can tell you one thing. They still go black when its way too rich.
tony-devon
posted on 19/5/10 at 02:34 PM Reply With Quote
I still tune my bikes this way
just remember that lean kills engines, rich kills plugs, I know which is the cheapest to replace
heavy is good, heavy is reliable, and if it breaks, hit them with it
big-vee-twin
posted on 19/5/10 at 02:42 PM Reply With Quote
Yep, still works I understand
http://www.triangleltd.com
ReMan
posted on 19/5/10 at 03:26 PM Reply With Quote
Proper mechanicing
Madinventions
posted on 19/5/10 at 03:29 PM Reply With Quote
And they go when you're running horribly lean...!
Link to previous thread
Ed.
View my band website:
http://www.shadowlight.org.uk
posted on 19/5/10 at 03:39 PM Reply With Quote
The Haynes manual for the ST1100 still talk about the chop being used to tune....
atspeed racing
posted on 19/5/10 at 04:21 PM Reply With Quote
A plug cut would tell you the average fueling, and could be a help.
If you looked at a plotted dyno sheet, if the mixture is a little on the lean or rich side at a certian RPM, you would see a slight fall in the BHP and torque. You would never see this on a plug cut and would never know.
We have seen 5 BHP on a 100BHP car at lower RPM, we corrected this and the car sounded no different than it did before.
RichardK
posted on 19/5/10 at 06:00 PM Reply With Quote
Yep that how I take a look at the mixture on my lads bikes, still works for me.
Rich
Gallery updated 11/01/2011
norfolkluego
I can confirm that and that they go a nice tan biscuity colour when OK, worryingly my car gives me two plugs of each colour at the moment, should balance out shouldn't it
Fred W B
posted on 19/5/10 at 06:48 PM Reply With Quote
Thanks for the speedy responses guys.
Trick with the two strokes always was to get as close to lean as you dare, as the engine made best power then.
There was a fashion in the kart racing at a stage to run the top end mixture so lean it would just about sieze at the end of the longest straight, this was prevented by momenterialy choking the air intake with your hand (to pull in extra fuel) just before the critical point each lap.
Fred W B
[Edited on 19/5/10 by Fred W B]
dhutch
posted on 19/5/10 at 07:59 PM Reply With Quote
Its not untrue!
austin man
posted on 19/5/10 at 09:01 PM Reply With Quote
this has been the method that I have set my twin 40's on a 1.8 zetec along with balancing the carbs and I have done 7000 trouble free miles. My old many swore by this method, he was a mechanic for 50 years
