Nitrogeno25
| posted on 27/5/10 at 02:27 PM |
Throttle bodies again GSXR
I like the idea to switch my engine to EFI and been offered GSXR600 TBs.
The look like these:
I read over the forum that they should be respaced.
But it seems there are 8 injectors. I can removed a set of 4 but I don't know the specs of them. Does anybody use these "new" GSXR
TBs?
Thank you very much!
[Edited on 27/5/10 by Nitrogeno25]
nre
| posted on 27/5/10 at 02:55 PM |
Those particular ones are 'paired' so not individually re-spaceable. Could still be used, but not quite so easy...
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
big-vee-twin
| posted on 27/5/10 at 03:01 PM |
You need some from a 2001 bike
[Edited on 27/5/10 by big-vee-twin]
http://www.triangleltd.com
Nitrogeno25
| posted on 27/5/10 at 04:16 PM |
Thanks guys, I know these are in pairs, but they can be easily spaced in the middle. I know it's not the best solution but the price is right
and are in great condition
As for the injectors, I don't know the specs of each bank, are the 8 injectors the same?? Seems not.
Thanks again.
Fatgadget
| posted on 27/5/10 at 04:35 PM |
I see no reason why you cant just leave the secondary set unused.If Im not mistaken,the secondary set of injectors are for part throttle..a bit like a
twin choke carb. Get a set of 4 to match your engine spec and job is a gud un!
