scutter
| posted on 15/8/10 at 09:19 PM |
Exhaust collector cad work needed.
Folks, I'm currently having trouble getting my head around how each individual pipe is shaped (fish mouthed) in a 4-1 merge collector.
I was thinking, would anyone with CAD knowledge be able to draw one up then seperate the pipes or does anyone have a pic of a single cut pipe.
If sizes were needed how does 1 3/4" or 44.5mm tube with a 15deg angle into the collector, as thie size pipe could be brought ready bent.
This info could be useful to quite a few people, so thanks wouldn't only be mine.
ATB Dan.
[Edited on 15/8/10 by scutter]
clairetoo
| posted on 15/8/10 at 09:34 PM |
Theres a bit of a `how to' guide here
Its cuz I is blond , innit
Claire xx
Will weld for food......
scutter
| posted on 15/8/10 at 09:37 PM |
Thanks for that Claire, I kinda know the theory, it's just getting my head around the shapes without going through £60 of steel tubing
I'd tack it together and get the coded welders on camp to finish the work.
ATB Dan.
PSpirine
| posted on 15/8/10 at 09:57 PM |
I can stick it together for you in Solidworks (might need to give me till Tuesday/Wednesday).
Just let me know exactly what angles you want the 4 pipes coming in at, and the OD/ID (so I put the right thickness in) of pipe.
Pavs
iti_uk
| posted on 16/8/10 at 08:34 AM |
I have cobbled together a quick model in Catia - I've saved the individual runner as an .igs file, and also the assembly (four of them together)
as another .igs file for reference. I have also attached the .CATPart and .CATProduct, just in case you are able to open those - the operations I used
to make the models are exactly the same as you use in real life - two "flat" cuts up the sides, then one cut across the top.
(how do I attach the zip file?!?)
(subsequently emailed the zip file. This site needs to allow attachments within the forum!)
Chris
[Edited on 16/8/2010 by iti_uk]
nnrouty
| posted on 18/8/10 at 01:01 PM |
Hi
Im a Technical CAD Technician in an Archtects office.
I've put this together but not sure if it exactly right.
[img]Image deleted by owner[/img]
As long as its fast.... i don't care
