Author: Subject: webber 45s problems
lewis
posted on 29/8/10 at 07:20 PM Reply With Quote
webber 45s problems
hi all, i bought a mk indy about 3 weeks ago running sweet as a nut but now when i start the car unless i rev it it stalls and im getting popping from exhaust and from the rear most carb,the engine is a 2.1l pinto with a piper cam the carbs are webber 45s only thing i have touched is i retorqued the carb to manifold bolts as they seemed a little loose,im new to carbs so not really sure where to start and dont want to screw them completly
Xtreme Kermit
posted on 29/8/10 at 07:24 PM Reply With Quote
Webers should be mounted with misab plates and sprung washers.
They should move up and down about 1cm at the trumpets, otherwise vibration from the engine may cause frothing in the float chamber and knock the tuning out.
Loosen the fasteners back off again and see if it fixes it.
austin man
posted on 29/8/10 at 07:29 PM Reply With Quote
by tightening the nuts you may have affected the balance this happened to me took ages to reset them. They should be able to move if not it is understood that they start to froth up, Misab and thackarey washers needed. You may get away with slacking the nuts , get the car running and loosen the nuts gradually keep listening to the engine note
lewis
posted on 29/8/10 at 07:36 PM Reply With Quote
oops you live and learn i did say i know cock all,ill try that and report back any idea how much to back them off?
lewis
posted on 29/8/10 at 07:48 PM Reply With Quote
Thanks guys!!! All good now, if it ain't broke don't fix it!!!
austin man
posted on 29/8/10 at 08:16 PM Reply With Quote
back the nuts of gently with etha engine running and listen for the engine note. If you have thakarey washers fitted I think you leave . .22 gap between the spring washer
