Author: Subject: silvertop 95
col
posted on 29/8/10 at 09:53 PM Reply With Quote
silvertop 95
Hi Guys, ive a 1995 silvertop 1.8 which will have zr6 carbs fitted.........If i offer this up for iva,would it fail on emmisions? also would i need to fit a catalyst?
I will be using megajolt and the cams will be from the 2litre.
Cheers Col
cd.thomson
posted on 29/8/10 at 10:24 PM Reply With Quote
hi bud,
do you have evidence of when it was produced in 1995, i.e. what month?
If no, or if it was after august then you'll need to be fitting a cat to get it through IVA. Otherwise you should be able to get it through without.
Craig
mcerd1
posted on 30/8/10 at 07:39 AM Reply With Quote
like craig says you'll need to be able to prove when it was made - but since its a ford, take the first 2 letters of the engine code and looke them up here: linky
you might still need some offical letter to state that, but some people have managed with the page out of that cataloge
[Edited on 30/8/2010 by mcerd1]
col
posted on 30/8/10 at 11:05 AM Reply With Quote
Thanks for the replies guys, ive managed to locate the "new keeper supplement"which states it was registered in 08 03 1995.......and i do have a copy of the reg docits at work which will show the vin number.
mcerd1
posted on 30/8/10 at 05:45 PM Reply With Quote
its the engine number thats important so best to check whats actually stamped on the block (incase the donor has had a new one at somepoint in its life)
col
posted on 30/8/10 at 07:46 PM Reply With Quote
Yup the blocks at work too,......will check tomorrow...thanks again
col
posted on 31/8/10 at 08:20 PM Reply With Quote
checked block at work.....seems to just have cast numbers etc an 1.8 on it......any idea where its located?
mcerd1
posted on 1/9/10 at 12:13 PM Reply With Quote
^^ according to mr haynes it should be stamped on the front of the block somewhere....
(2 letters then 5 numbers)
[Edited on 1/9/2010 by mcerd1]
col
posted on 1/9/10 at 04:40 PM Reply With Quote
Chthe vin info which states its a "seers again, Ill check it out in the morning. ive found the vin docits which states its a "sc" block if it marrys up with the block then its a January 95 engine....wahoooo! THanks again for your input.
col
posted on 1/9/10 at 04:42 PM Reply With Quote
Even i cant understand the first part???? what went on there!
posted on 1/9/10 at 04:59 PM Reply With Quote
Engine number is stamped on the block nearside beside the VR sensor.
You need to send it to Ford Technical Dept to get a letter to prove when it was built.
Ford Technical Information Dept.
PO Box 300
Walsall
WS5 4QH
col
posted on 1/9/10 at 05:24 PM Reply With Quote
Thank you young man,.....Walsall eh, just a hop skip an a jump from me....cheers!
col
posted on 2/9/10 at 05:02 PM Reply With Quote
Finally, ive found the number,an yes it ties up with the vin plate: its a sc37738 rkA thanks everyone much abliged
