jono2020
| posted on 1/9/10 at 07:59 PM |
Oil PSI changing...
The Oil pressure on my car usually around the 60 mark and between 30-40 when stationary. Today when I took it down the road, about 2 mins into my
journey I noticed the pressure was nearer to 80/90. Idle was about 40-50. Also when I rev the engine the oil pressure is rising and falling which it
doesn't usually do. Does anyone know what this could be... It has had an oil change about three weeks ago...
franky
| posted on 1/9/10 at 08:02 PM |
what engine is it?
jono2020
| posted on 1/9/10 at 08:05 PM |
2.0 zetec
jono2020
| posted on 1/9/10 at 08:06 PM |
2.0 zetec
Canada EH!
How cold is it? Sounds like someone put heavier viscosity oil in at the last change.
Did it settle down after the engine was at proper operating temp? We get that here in Canada in the winter because of -20C temps.
jono2020
2.0 zetec
jono2020
2.0 zetec...
whitestu
Oil pressure should rise and fall with revs. It will also be much higher when the oil is cold.
MakeEverything
| posted on 1/9/10 at 08:07 PM |
Sounds ok to me with fresh oil.
Kindest Regards,
Richard.
jono2020
| posted on 1/9/10 at 08:09 PM |
Oh ok, maybe I have just never looked at the PSI just when I start out. Just wanted to check there wasnt any major fault with it. Also sorry about
posting the engine size so many times, I thought my comp froze so I kept hitting 'post reply'
se7en
| posted on 1/9/10 at 08:14 PM |
I thought you had a 8 Litre Zetec
jono2020
| posted on 1/9/10 at 08:16 PM |
If I had an 8ltr zetec I would prob be dead by now. Or the happiest guy in the world, you just wouldnt be able to tell as I was doing 250mph
everywhere... But prob dead
britishtrident
| posted on 2/9/10 at 07:40 AM |
Assuming you used the correct oil grade it would appear the oil pressure relief valve is stuck
[/I]
jono2020
| posted on 2/9/10 at 01:18 PM |
Yer Im pretty sure I used the right oil grade. It has only just started happening tho to my knowledge so surely that would of happened as soon as I
put the oil in...
whitestu
| posted on 2/9/10 at 08:15 PM |
Why? Those oil pressure readings for cold oil seem about right to me.
Stu
flipper123
| posted on 16/2/11 at 08:11 PM |
sounds good too me nothing unusual there dude. did you use 5w 30 castrol ford oil. thats what i was told to use by ford for zetecs fully synthetic
stylus fever!!!!!!!!!!!!
