jono2020
| posted on 1/9/10 at 08:14 PM |
Engine cutting out
After driving the car quite furiously the engine doesn't like to stay on... The revs will just cut out then I have a problem starting it again.
It has twin webber 45's on it and I'm not sure when they were last balanced, would that be the problem. Also it doesnt always start first
time and the starter motor makes a bit of a grinding noise sometimes. Would that be a related problem...
MakeEverything
| posted on 1/9/10 at 09:16 PM |
Sounds like fuel evaporating?
Kindest Regards,
Richard.
| posted on 1/9/10 at 09:22 PM |
Has the problem only been there since the oil was changed?
jono2020
| posted on 1/9/10 at 09:41 PM |
No it was like that before...
mookaloid
| posted on 1/9/10 at 11:12 PM |
Sounds like fuel starvation of some sort. Have you checked the fuel pump?
mark
jono2020
| posted on 2/9/10 at 01:17 PM |
Im not fantastic with mechanics so I will get my mate to look at it and check the fuel pump for me
flipper123
| posted on 16/2/11 at 08:24 PM |
i had the same problem before it was set up on a rolling road i would floor it and it would cut out leave it idol for ten mins and warm up and it
would be ok, it didnt have the correct fuel air ratio once it was revving high it. it was really annoying thats why i got it set up on a rolling
road. the starter motor was from the sierra doner and was on at the end of its life then. i gave a p100 starter to the guy to fit, which was a brand
new one i never got round to doing it. seams like it was never done. westfield use a slimline one. but im not sure what it comes off, but it spins
like a banshi and is very powerful. maybe find out what they use and try that. thats what my mate has on his westy zetec.
another good mod is the raceline water rail gets rid of the header tank? also looks fanny tastic.
stylus fever!!!!!!!!!!!!
