couch22k
| posted on 13/9/10 at 03:23 PM |
Pinto Breather Take Off Valve
Ive just bought a breather take off elbow for my Pinto to go to a oil catch tank and im not sure about the set up.
Is it like this, with what im guessing is a sort of baffle out off the block.
Or do i remove everything and have it going straight into the block.
Stott
| posted on 13/9/10 at 03:33 PM |
Supposed to be the 1st one IIRC, the lower half is a flame trap and the top half is the pcv valve, both should be run together.
I just use a brand new (Burtons) OEM PCV valve and the flame trap
Does that elbow have the valve in it though or is it just hollow?
HTH
Stott
EDIT: just re-read. If you are using a tank then I guess you won't need the valve, if it were plumbed to vacuum as std then you'd need
one
Stott
[Edited on 13/9/10 by Stott]
couch22k
| posted on 13/9/10 at 03:44 PM |
Cheers Stott
I guess i still need the flame trap then.
Wish I knew you needed a PCV valve i got one from Burtons too, then had to order this one after i realised it was no good with a tank.
Stott
| posted on 13/9/10 at 03:46 PM |
Nevermind, at least it only done you for about £6 whereas Ford wouldn't sell me one separately, only together with the trap, and it was just shy
of £40!!!
no - thank - you, mr ford parts person
EDIT: that sounded like I bought it from ford, I didn't I laughed a bit, then rang burtons, lol
| posted on 13/9/10 at 04:09 PM |
I ran mmine the 2nd way although I had to turn a little off the diameter to get a good knock in interference fit in the block. Run a suitable oil
safe hose up as high as possible then back down into a vented catch tank. Use a hose clip to secure the hose to the breather elbow or it will leak
What breathing arrangement have you got on the rocker cover? I ran a filler cap with breather take of plumbed into the same catch tank.
If the engines healthy and properly vented up top and the sump is well baffled you should get little or no oil vented into the catch tank - maybe a
bit of oily condensation at worst.
jacko
| posted on 13/9/10 at 04:25 PM |
You will not need a valve if you are going to a catch tank.
If you do use a valve and the pipe it is not connected to the carb / inlet manifold to get a vacuum to open the valve you will presser the sump and
blow oil out of the rocker filter
Jacko
RichardK
| posted on 13/9/10 at 05:04 PM |
2nd picture defo
Gallery updated 11/01/2011
couch22k
| posted on 13/9/10 at 05:17 PM |
Yes, im running it with a take off from the filler cap to the same catch tank which is vented (see piccy) Think this is right.
I'll take it to my friendly engineering company to get it turned down a little.
Thanks all for your help.
RichardK
| posted on 13/9/10 at 07:19 PM |
I wanted mine to go straight up so used the burton one as a template.
This maybe of use, it should be a tight interference fit, sjust a few taps of a rubber mallet should be enough, doesn'nt have to go all the way
down.
Rich
| posted on 13/9/10 at 08:38 PM |
Spot on IMO and...if I might say, what a ridiculously clean and well rpesented engine bay you have there
Stott
| posted on 14/9/10 at 06:03 AM |
down.
Rich
That's not the PCV valve though, for anyone reading this, running a std breather and who is now confused. The left most item in your photo is
the flame trap, the pcv valve pushes into the top of this.
If you are running a catch tank then you can replace it with a turned up elbow or straight bit, but then you can use it either with or without the
trap. There's no point in leaving it out IMO as it makes a good seal as std with the fit to the block and the grommet to seal to the
valve/elbow.
This is the PCV valve, which pushes into the bit on the left of your pic:
[Edited on 14/9/10 by Stott]
flak monkey
| posted on 14/9/10 at 06:53 PM |
The first pic is correct. The PCV valve would have been fitted to the flame trap as a seperate item.
The elbow DOESNT go straight into the block!
Sera
http://www.motosera.com
RichardK
| posted on 14/9/10 at 07:06 PM |
I stand corrected then, I stuck mine into the block as it wasn't a good fit in the flame trap thingy ( I thought that was the pcv valve as its
got a spring and shutter inside when I took mine apart)and it kept falling out! Since then always thought that's where its meant to be.
Rich
[Edited on 14/9/10 by RichardK]
couch22k
| posted on 14/9/10 at 07:22 PM |
Thanks all
Dropped it off at engineers today to get it turned down for a better fit.
DRC INDY 7
| posted on 14/9/10 at 07:28 PM |
I have mine fitted to the flame trap and to stop it vibrating loose i superglued it to the rubber its still there after 2000 miles running this year
to date
Puddle Dodgers Club
