Author: Subject: XE Clutches
posted on 18/1/11 at 03:08 PM Reply With Quote
XE Clutches
Took my engine out to paint it and was a bit surprised at how small the clutch is.
Is this standard for a 2.0XE???
It's Evolution Baby!
blakep82
posted on 18/1/11 at 03:17 PM Reply With Quote
ooh, no that looks a bit special to me!
mine (although a later ecotec) the clutch is a lot bigger. mine uses a sierra plate, i forget what size.
don't think i got pictures of mine, but thats not standard i don't think
this is a bit more like it
[Edited on 18/1/11 by blakep82]
________________________
posted on 18/1/11 at 03:19 PM Reply With Quote
Cheers Blake... the guy I bought the car from rattled through the spec when we met, but it was never written down. I then promptly forgot!
I've tried getting back in touch with him to find out more, but he's gone quiet!
I remember him saying he had a mate who worked for Alcon and that he had supplied the brakes and some other 'stuff'... maybe thats where the clutch is from.
tomgregory2000
posted on 18/1/11 at 03:20 PM Reply With Quote
some one has spent MEGA money on that clutch
twin plate 7 and a half inch by the look of it, prob abot £700-£1000 worth of clutch
Yum Yum
omega 24 v6
posted on 18/1/11 at 04:49 PM Reply With Quote
Special clutch and quite a tasty bit of gear luck you.
Should be some markings on it somewhere I would imagine.
posted on 18/1/11 at 05:23 PM Reply With Quote
Oooh... cool!
Cheers guys - I'll try and find some markings on it tomorrow.
posted on 18/1/11 at 07:35 PM Reply With Quote
And any clues what this is on the sump?
omega 24 v6
posted on 19/1/11 at 12:25 PM Reply With Quote
Yep that'll be the old oil level switch to let you know when to top it up. ( mainly for women as men do check oil regularly )
Fozzie and Clairetoo excepted of course cause they are special.
posted on 19/1/11 at 02:42 PM Reply With Quote
Thanks!
NS Dev
posted on 20/1/11 at 09:39 PM Reply With Quote
you're a jammy sod!!!
That is an expensive clutch!!
We've just paid £600 for something similar in the kadett c turbo, plus 120 quid for the billet flywheel!
perksy
posted on 20/1/11 at 10:23 PM Reply With Quote
Thats the Oil level sensor
and that Clutch is Big money
Don't take this the wrong way but There seems to be an awful lot of sealant on the mating flange of the sump and it would be worth removing the sump and making sure none of the sealant has found its way into the Bottom of the sump
*If* it clogs the oil strainer or gets into the oil pump it won't have a happy ending
I stripped a Zetec engine once which was similar and the Gasket sealant had blocked half of the oil strainer
[Edited on 20/1/11 by perksy]
posted on 21/1/11 at 07:35 PM Reply With Quote
Cheers. I was thinking that I might as well change the oil-pump whilst the engine is out, so will see if there is any gunk inside!
perksy
posted on 21/1/11 at 11:39 PM Reply With Quote
Funny enough just ordered an oil pump from Autovaux for an XE engine i've got here for local westy owner
Have the data/tolerances here for the oil pump if you need it, but *if* its scored Badly internally there ain't much you can do
[Edited on 21/1/11 by perksy]
posted on 22/1/11 at 11:04 AM Reply With Quote
Any real-world advantage to getting the uprated SBD one... is it an extra £150 well spent!?
perksy
posted on 22/1/11 at 01:18 PM Reply With Quote
Depends what its going to be used for to be honest
Standard one is fine for fast road use but if your going to drive the nads off it regularly on Track days etc it might be a good insurance policy
What can happen is that the gears in the standard oil pump can break up given enough abuse, although i've seen a few XE's given plenty of abuse on the standard ones
Also the standard Timing Disc on the Crank can also Crack up with contiued abuse and alot of competition XE's use an external timing disc and sensor
Trouble is with these things you can keep going and going and spend shed loads if you want to
posted on 22/1/11 at 01:28 PM Reply With Quote
Yep... know the feeling well!
Thanks for the advice!
daniel mason
posted on 22/1/11 at 01:31 PM Reply With Quote
sell the clutch.
sell the engine
sell the gearbox
and go s2000 scott. you know you want to! lol
posted on 22/1/11 at 01:38 PM Reply With Quote
Ha ha... I was totting up what I think the engine and box is worth and it could probably work out!
