Fishface
| posted on 27/1/11 at 08:37 PM |
starter motor engaging
I just had one dumb question on starter motors. Do the spin up, slide up the central spindle thing , engage and then drop back down again once turned
off. Im sure on my pinto it just engaged straight in upon fitment.
Nash
| posted on 27/1/11 at 08:48 PM |
When you turn the key this energises the Starter solinoid and fires the bendix into the teeth of the flywheel. When the car fires and you release the
key back to the run position the bendix is disengaged and returned to its "rest" position away from the teeth of the flywheel. If it
doesn't disengage the starter motor would burn out.
..............Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
prawnabie
| posted on 27/1/11 at 10:50 PM |
Except when the starter is also the alternator!
rallyingden
| posted on 28/1/11 at 10:56 AM |
Not heard of starter / alternators before What are they fitted to ?
RD
| posted on 28/1/11 at 11:47 AM |
RD
IIRC the old plastic pig invalid carriages had them or at least a starter/generator . They may have used a Sach single cylinder engine ? Other than
that I can't think of any unless some of the very early Honda cars like the S800 used them?
