Author: Subject: Dismantling A Ford distributor
omega0684
posted on 2/2/11 at 08:27 AM Reply With Quote
Morning All,
I need to make a blanking plate your my distributor hole on the side of the block (Pinto for those who don't know) i have started taking an old dizzy apart so that i can use the shaft from inside but i have come to a bit of a stumbling block. I have managed to take most of the internals out apart from the pieces right at the bottom. There seems to be something preventing me from taking out the bottom part of the internals which is linked to the cog that drives the oil pump.
Anyone know how to get this part of the internals out, i would imagine once released the shaft should just side out from the casing?
All the best
Alex
mcerd1
posted on 2/2/11 at 08:39 AM Reply With Quote
from memory isn't there a roll pin though the shaft at the bottom somewhere on the outside (I'll dig out some books later...)
I take it you making an oil pump drive - I got one made for me by the guys at H&H in strait swap for some old dizzys that they needed - I'll dig out a pic later if you like
or are you going for a dry sump instead
btw - is it a bosch one (orange cap) or a motorcraft one (black cap) ? (not sure if it make much difference)
and is it a points type or an electronic one ?
[Edited on 2/2/2011 by mcerd1]
omega0684
posted on 2/2/11 at 09:40 AM Reply With Quote
looks like its an old electronic one. a mate has just dry sumped his 2.4 pinto and its cost him nearly £2000 so i think a wet system will be more than adequate for what im going to be using it for!
i'll knock the roll pin out nad see what happens, im thinking that the internal shaft will need cutting in half anyway
mcerd1
posted on 2/2/11 at 12:08 PM Reply With Quote
if its an electronic one with a vac. advance - then it might worth chopping a different one instead (u2u sent)
dave r
posted on 2/2/11 at 05:58 PM Reply With Quote
roll pin on the bottom cog, needs to come out
cog pushed, off, then the shaft will fall out
on mine, when i did the same mod, i machined the wider part of the body off, an used the platform it left to mount my coil pack
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
mcerd1
posted on 2/2/11 at 06:27 PM Reply With Quote
they have actually turnned down the body in a lathe and cut a grove for an o-ring
