gavin174
| posted on 2/4/11 at 12:38 PM |
tranX lsd
trying to fit a tranX lsd to a sierra 7" diff
followed the instructions to the letter and getting tight spots....
taken it apart and totally cleaned all faces and rebuilt..
same problems..
obviously this is needs to be right..
can anyone recommend someone to set it up properly..
ideally in Essex or sorrounding area.
flak monkey
| posted on 2/4/11 at 01:06 PM |
Too tight, give it a little more backlash.
Mine was the same.
Sera
http://www.motosera.com
gavin174
| posted on 2/4/11 at 01:10 PM |
but that will just make the clearance bigger at the loose spots
loose spots set to 4 thou clearance..
but very tight, if no clearance at tight spots
[Edited on 2/4/11 by gavin174]
fimi7
| posted on 2/4/11 at 01:38 PM |
Do you have a dial indicator. Check the rotation of the gear to see if it is out of round. If it is, you might have a bad bearing on one side or the
other.
I am assuming that it binds in the same spot.
--- Ali
Chippy
| posted on 2/4/11 at 02:33 PM |
These people are very good, had mine done by them. HTH Ray
Trans clicky
