Hammy360
| posted on 10/4/11 at 09:13 PM |
Modded zetec sump from scholar
apologies for starting this thread again but does anyone else know how to fit the oil pick up supplied with the scholare sump? they did tell me on the
phone that dependant on the age of the engine it can be 'tricky' My zetec is 1999 and the pick up doesnt just bolt on.....
mazie
| posted on 10/4/11 at 09:40 PM |
my zetec is a 1998 model . didn't have any issues . Don't forgot a new gasket between pickup and block. A slight wiggle of the sump was
needed to line in up correctly.
femster87
| posted on 10/4/11 at 09:42 PM |
just had a look at your blog. Can you not widen the slot on oil pipe pipe so you can bolt it on?
Hammy360
| posted on 11/4/11 at 06:11 AM |
thats what I was thinking but didnt want to start down the wrong route, hope fully someones come across this before. Pics on my blog
http://hammyszero.blogspot.com/
[Edited on 11/4/11 by Hammy360]
Norfolkluegojnr
| posted on 11/4/11 at 07:37 AM |
Hammy, I had this issue with my scholar sump. my engine is a 2000 reg blacktop. Easy when you know how.
1. bolt down windage tray
2. lightly bolt down pipe leaving 2-4mm space between faces
3. GENTLY pull the pipe round and drop it over the third mounting point. You will need to bend it, but go slow so you dont break it. it does meed to
come round a fair bit, but the steel is quite soft.
4. nip up tight on everything. make sure you have a good tight seal at the faces.
It feels wrong whilst you are doing it, but it works. I have 85-90psi oil pressure all day long.
HTH
Hammy360
| posted on 11/4/11 at 07:50 AM |
Thanks for that! The guys a Scholar have just phoned and said the same thing. Well recommended company !
Cheers everyone
