Author: Subject: struggle with 2nd gear on down change
nickw2000
posted on 18/4/11 at 07:06 PM Reply With Quote
on the down change sometimes i struggle to f is find the 2nd gear, every other gear in good with a blip of the accelaerator
just sometimes goes in no problem to 2nd gear but sometimes struggle and cant find the gear, and end up stopped at a junction and roundabout can get in a gear!
any help please?
posted on 18/4/11 at 07:11 PM Reply With Quote
A bit more information might be a good idea such as what gearbox? is it a BEC or a CEC?
JimSpencer
posted on 18/4/11 at 07:13 PM Reply With Quote
Hi
Type 9?
If so then before trying anything else, is there any significant left to right play in the gear lever when the cars in gear?
If so then replace the saddle clip (sometimes called rail clip) on the bottom of the gearlever.
Hellfire
posted on 18/4/11 at 07:17 PM Reply With Quote
Did you try any of the suggestions in this post?
Phil
nickw2000
posted on 18/4/11 at 07:21 PM Reply With Quote
oh sorry
its a type 9 ford gearbox on a 2.0 pinto block
nickw2000
posted on 18/4/11 at 07:25 PM Reply With Quote
Phil
no sorry i didnt find anything from this post
flak monkey
posted on 18/4/11 at 07:28 PM Reply With Quote
If everything else checks out (i.e all other gears are ok) its a common synchro problem on the T9 box. Second gear gets a lot of stick on hard acceleration.
Also what oil are you using in the box? Some oils make gear changes a pain unless the oil is nice and hot.
Sera
http://www.motosera.com
nickw2000
posted on 18/4/11 at 07:29 PM Reply With Quote
Originally posted by JimSpencer
Hi
Type 9?
hi is this the plastic saddle? is so yes i changed this, made a difference with 3rd gear and reverse but just 2nd having the issue
nickw2000
posted on 18/4/11 at 07:37 PM Reply With Quote
it gets worse as engine warms, just the standard recomended gear oil for type 9
flak monkey
posted on 18/4/11 at 07:45 PM Reply With Quote
75w90 GL4
Try something like Fuchs Syn 5
If its the synchro, try to double declutch, if you get it right it will go in easy.
Or do what most people do, pull harder on the lever and swear at it
Sera
