Author: Subject: brain fart
chrisbeale
posted on 19/4/11 at 03:51 PM Reply With Quote
brain fart
im having a brain fard at the moment, cross flow tappets, how do i know for definate when a valve is fully open or closed without just looking?
adithorp
posted on 19/4/11 at 04:05 PM Reply With Quote
Turn it via the crank pulley untill inlet No1 fully open, set inlet No4, Ex No1 fully open set ExNo4 and so on. Don't see how else you'd do it with out looking unless you want to do it by feel in the dark... or why you'd want to do it with your eyes closed...
http://jpsc.org.uk/forum/
UncleFista
posted on 19/4/11 at 04:06 PM Reply With Quote
Google "rule of nine", I'd link, but it's a pain when I'm on my phone
Tony Bond / UncleFista
chrisbeale
i mean, is it only by looking at the valve and rocker arm until it stops going fully up that you can tell?
westf27
posted on 19/4/11 at 05:37 PM Reply With Quote
You can do it visually by marking the crank pulley when the valve just stops opening and again as it starts to close.Set the crank pulley in the middle and adjust appropriate valve.If you have a dti then even greater accuracy can be achieved.
555
omega 24 v6
posted on 19/4/11 at 06:04 PM Reply With Quote
Rule of nine works fine. IIRC number the tappets from 1 to 8 front of block to rear or vice versa then turn crank till you see one fully compressed then alter/adjust 8 8+1 =9
then turn till 2 is fully compressed and alter 7 7+2=9
etc etc.
chrisbeale
posted on 20/4/11 at 06:02 PM Reply With Quote
ok job done all se, thanks guys.
