DixieTheKid
| posted on 13/8/11 at 08:28 AM |
Difference between 205 Cosworth Block & 205 Pinto Block
I was asked the question above, i didnt have an answer so i thought i would find out. Answers on a post acard please
COS IT'S Worth IT
jacko
| posted on 13/8/11 at 09:03 AM |
The sierra 205 block is the same as the cozzy iif you look behind the dizzy there is 4 numbers ie ---1111 or 2222 the blocks with the 1111 were used
for cozzy's as they have better tolerances
The cozzy's use a different crank
Jacko
DixieTheKid
| posted on 13/8/11 at 09:20 AM |
oh ok, thanks!
COS IT'S Worth IT
BigFaceDave
| posted on 13/8/11 at 09:38 AM |
Jacko
I could be wrong but I was told its any number that only consits of 3's and 1's e.g. 1111 or 3333 or 3131 1133 etc you get the idea, how
true this is I dont know but I have heard it from 2 different people both who seemed to know alot about cosworths.
mcerd1
| posted on 13/8/11 at 11:26 AM |
according to fords cossie manual its only blocks with grades 2 or 3 - the example it gives is 2232
(my block came from a granada and was graded 2322)
but I'm gessing you'll have to get the bores redone anyway so the factory grades won't matter
the really difference is in what they fitted to the bare block - I think they changed nearly every part....
[Edited on 13/8/2011 by mcerd1]
BigFaceDave
| posted on 13/8/11 at 11:45 AM |
It may have been 2 instead of 1 then! I dont have the greatest memory! Mines got 3333 stamped on it so 3 is the number im sure about!
DixieTheKid
| posted on 13/8/11 at 11:53 AM |
Yes i would to thought all of the internals are different. Good info, thanks! You learn something new every day!
COS IT'S Worth IT
jacko
| posted on 13/8/11 at 05:39 PM |
Well mine has four 2222 if that helps
