Author: Subject: 1.8 blacktop to type 9 gearbox
JohnH
posted on 19/8/11 at 07:47 PM Reply With Quote
Hi, I have a 1.8 blacktop,and a type 9 gearbox.Can i use the 1.8 flywheel ? I have anew clutch.But the clutch cover i have is from the 1.8 blacktop. Looking forward to your help.Thanks. John
big-vee-twin
posted on 19/8/11 at 08:00 PM Reply With Quote
Yes, you will also need a CT133 thrust bearing, a spigot bearing to fit into the fylwheel centre which supports the input shaft and a Pinto friction plate for the clutch which has the correct number of splines.
Most people use the 1.8 flywheel on the 2.0ltr engine as its lighter.
http://www.triangleltd.com
lotusmadandy
posted on 19/8/11 at 08:06 PM Reply With Quote
Hi John
The 1.8 flywheel and pressure plate will be fine
i used them with a mondeo 1.8 friction plate,pinto spiggot
bearing and cct133 release bearing.
Just ensure the friction plate is 220mm with a 23 spline centre
and all will be fine.
avagolen
posted on 19/8/11 at 08:20 PM Reply With Quote
Hi John,
Just a point to be aware off that I found out when fitting the clutch to my slivertop.
The clutch pedal on my Fury was designed with quit a long throw - Pinto clutch I think.
When I fitted the zetec pressure plate I noticed that the pedal felt strange as if it was going over a fulcrum.
The clutch would disengage and then re-engage as I pushed the pedal further.
I corrected it by shortening the lower half of the pedal and the result was a longer throw and a lighter clutch
with no re-engagement.
Len.
The Answer for everything, but never the last word....
JohnH
posted on 19/8/11 at 08:32 PM Reply With Quote
Thanks guys... o one other point, what starter would you use ? Thanks again...John
lotusmadandy
posted on 19/8/11 at 08:55 PM Reply With Quote
You need a lucas lrs707 from a cvh or twincam.
If you are using the silvertop sump
you can use a pinto motor with a 14mm spacer.
JohnH
posted on 19/8/11 at 09:58 PM Reply With Quote
Thanks Andy. Hope to catch up one day,as i am only 20 miles from the toon......... John
