Jos Fury
| posted on 1/9/11 at 10:34 AM |
Gearshift lever shaking/vibrating excessively on MT75
Dear forummembers,
My gearbox lever is shaking / vibrating excessively, only when driving.
When I drive and press the clutchpedal ( fully ) the vibrating goes away.
Where should I start looking ? Balancing propshaft ?
snapper
| posted on 1/9/11 at 11:30 AM |
First check the remote gearlever, this is known to come loose or break a weld making the lever go all floppy.
Check gearbox and engine mounts.
I eat to survive
I drink to forget
daviep
| posted on 1/9/11 at 01:00 PM |
It can't be propshaft related, pressing the clutch does not stop the propshaft spinning.
Is this a sudden problem or has it always done it?
As above check all mountings and the bellhousing bolts.
Davie
“A truly great library contains something in it to offend everyone.”
Jos Fury
| posted on 1/9/11 at 01:54 PM |
thanx, will check !
looks like it is not the propshaft than.
if I put the car in neutral when driving at lets say 50mph, does the prop still spin as well ? just want to know.
SeaBass
| posted on 1/9/11 at 02:26 PM |
Yes - the clutch disconnects the gearbox input shaft from the engine. The gearbox output shaft and prop shaft to the rear will turn at all times the
car is moving, neutral or not. Maybe check the bolts holding the clutch cover to the flywheel.
[Edited on 1/9/11 by SeaBass]
roadrunner
| posted on 1/9/11 at 07:34 PM |
I have a similar problem on a Passat 1.8T, the stick vibrates at 3000plus revs and makes the lever rattle.
I have replaced all engine and gearbox mounts to no avail. I have been told it could be gearbox related or the just the start of somthing else.
Jos Fury
| posted on 2/9/11 at 06:07 AM |
thank you all for the replies so far. will look into the matter and let you know the outcome. might be helpfull for other's as well.
Jos Fury
| posted on 3/9/11 at 09:08 AM |
seems like the combo of gearbox/propshaft is maybe not ok.
took some pictures while having a closer look to how it is put together. thank's for your help yesterday Rob, nice lift started a new thread
to find how other people have connected the mt75 to a live axle.
[Edited on 3/9/11 by Jos Fury]
