theduck
| posted on 4/12/11 at 05:22 PM |
Fuel pump connections
I have this type of mechanical fuel pump on the pinto, which is the inlet and which is the outlet?
Thanks in advance.
Davg
| posted on 4/12/11 at 06:05 PM |
From your pict
Top - inlet from tank
lower - to carb
cheers
D
theduck
| posted on 4/12/11 at 06:08 PM |
Cheers.
lotusmadandy
| posted on 4/12/11 at 08:23 PM |
On mine the upper one was to the carb,the lower
one draws from the tank.
Sorry if im confusing you but thats how my pinto pump is.
Just been and checked the pump and thats how it is.
theduck
| posted on 4/12/11 at 09:03 PM |
Andy have you got a picture of your pump? Looking at that pic again mine might be very slightly different.
britishtrident
| posted on 4/12/11 at 09:05 PM |
You can blow through from inlet to outlet but not from outlet to inlet.
[/I]
| posted on 4/12/11 at 09:06 PM |
One will be an inlet and will have a vacuum when operated, the other, the outlet will have some pressure. Not too difficult to test?
theduck
| posted on 4/12/11 at 09:11 PM |
Thanks for the tips on how to check.
lotusmadandy
| posted on 4/12/11 at 09:15 PM |
Im not at home atm so cant take a photo.
As already said its easy to check,press the pushrod in by
hand and you will feel air pressure from the outlet.
Andy.
theduck
| posted on 5/12/11 at 10:33 AM |
No worries Andy, will check it tonight.
Thanks everyone for the tips. This is all very new to me but I'm learning with all your help, this forum is invaluable!
