needforspeed
| posted on 26/12/11 at 01:18 PM |
help with a trigger wheel
ok heres the trigger wheel on my 2008 r1 its 24-2 in the settings in the emerald ecu it asks for the degrees before tdc it triggers judgeing by this
picture it looks like 225 degrees??? can someone help me confirn this!
needforspeed
should add the picture is of the engine at tdc on cylider 1 with the crank sensor at the bottom
snapper
| posted on 26/12/11 at 01:26 PM |
Why way does it rotate?
If engine at TDC and sensor is at the position as drawn the the missing tooth looks to be 115 degrees ish.
I eat to survive
I drink to forget
needforspeed
| posted on 26/12/11 at 02:02 PM |
That's great thanks it rotates clockwise
snapper
| posted on 26/12/11 at 02:14 PM |
The missing tooth is recognised then 9 teeth later the crank reaches TDC
360 degrees = 24 teeth
180 degrees = 12 teeth
90 degrees = 6 teeth
Sensor is 9 teeth after TDC which means sensor triggered 135 degrees before tdc
I eat to survive
I drink to forget
needforspeed
| posted on 26/12/11 at 02:21 PM |
Fantastic thanks!! Il give that a go it's set at 90 now as it sounds like its about 45 out!!! Just kicking back ever so slightly!
