Author: Subject: process of the xe to type 9
Jamster1233
posted on 13/2/12 at 10:54 PM Reply With Quote
anyone know all componets needed for the xe bell housing to type 9 gear box
blakep82
posted on 13/2/12 at 11:06 PM Reply With Quote
hydraulic or cable clutch?
i'd go hydraulic, get the kit from rally design, and a clutch plate from a 2.3 diesel sierra. only difficult bit is which spacer you'll need for the clutch cylinder
________________________
Jamster1233
posted on 13/2/12 at 11:11 PM Reply With Quote
going for cable for now got half the stuff already
Ben_Copeland
posted on 14/2/12 at 06:35 AM Reply With Quote
Xe clutch plate
Ford friction plate
Ford release bearing
Rs2000 clutch fork
Vauxhall flywheel bearing.
Yuk from yukspeed can supply all these parts. Bit expensive mind.
Ben
Locost Map on Google Maps
Enter Your Details Here
snapper
posted on 14/2/12 at 08:56 AM Reply With Quote
Just curious why the RS2000 clutch arm?
I eat to survive
I drink to forget
Ben_Copeland
posted on 14/2/12 at 09:02 AM Reply With Quote
Think it's something to do with the alloy belhousing and clutch throw. I ended up with hydraulic clutch which was much easier than trying to get clutch arms to fit etc
Ben
Jamster1233
posted on 14/2/12 at 09:06 AM Reply With Quote
So is it best for rs2000 arm or another one ? May get the bellhousing from rwd/a frame any feedback on them ?
Ben_Copeland
posted on 14/2/12 at 12:12 PM Reply With Quote
No idea on them. Just go with cheapest main dealer. Yukspeed do them and yuk is very helpful.
http://www.rwdmotorsport.com/vauxhall-2-0xe-engine-to-ford-gearbox-cable-clutch-bellhousing/prod_10.html
Rwd Motorsport say to use the RS2000 clutch fork and bearing.
Ben
MikeRJ
posted on 14/2/12 at 12:56 PM Reply With Quote
I know for sure that the standard Sierra one does not fit.
Jamster1233
posted on 14/2/12 at 01:20 PM Reply With Quote
Do I need to change the sump really ??
daviep
posted on 14/2/12 at 02:26 PM Reply With Quote
Who mentioned changing the sump?
Davie
“A truly great library contains something in it to offend everyone.”
Jamster1233
posted on 14/2/12 at 02:30 PM Reply With Quote
Me lol have I got to have the gold wing sump
Ben_Copeland
posted on 14/2/12 at 08:17 PM Reply With Quote
Depends if there's a danger of twatting the sump on a bump. I have a caterham shortened sump.
Cheap way is to get the 8v steel sump and chop it down.
Ben
Ben_Copeland
posted on 14/2/12 at 08:20 PM Reply With Quote
Don't think a bike sump would fit lol
Ben
