Valtra
| posted on 6/5/12 at 10:57 PM |
running hot ...fuel issue ?
My beleaguered Twink was running hot as well as low pressured (oil ) both to and from Stoneleigh today . Am I correct in thinking lean fuelling could
make an engine run hot . It wasn't a scorcher of a day. Car didn't break down or boil over it just ran too close to the danger paint .
Maybe I was just more vigilant than usual because I was watching the oil pressure . Seemed to improve when I filled up with Shell on the way home or
is my imagination running overtime
"If it looks like it works and it feels like it works, then it works"
Valtra
| posted on 6/5/12 at 11:00 PM |
by the way I have a continuing issue with running on 3 cyls under some steady running conditions ...... Going to Megasqurt soon so hope to cure that
(and the low oil pressure at the same time)
cheers
snapper
| posted on 7/5/12 at 05:20 AM |
Lean duel and/or under advanced ignition.
Oil pressure could be blocked pickup, worn pump, if not its the mains.
I eat to survive
I drink to forget
Valtra
| posted on 7/5/12 at 03:04 PM |
