ryanill
| posted on 14/8/12 at 06:11 AM |
mechanical fule pump flow rate
hi all
i have noticed that at sustained high rpm my mechanical fule pump on my pinto is not suplying enough fule to my bike carbs. i have looked to find the
flowrate so i can compare to other electic pumps but carnt find a value for the mechanical. anyone got any ideas ?
FuryRebuild
| posted on 14/8/12 at 07:55 AM |
Yup - Pacet fuel pump and fuel pressure regulator. Problem solved for £100 or under.
Then you remove the fuel pump and little metal push-rod and make a blanking plate from whatever mild steel you have lying around. Lots of loctite and
it's done.
You have a second advantage now, which is that control to your fuel pump is switchable. I found this very handy on the rolling road when Boggs would
want the carbs empty for whatever piece of magic they'd work next. Run the engine, flick the switch to kill the pump, hay presto carbs empty 30
seconds later.
[Edited on 14/8/12 by FuryRebuild]
www.furyrebuild.co.uk
mcerd1
| posted on 14/8/12 at 09:47 AM |
for bike carb's a bike pump will work best and cost you the least
(just needs to be from a bike with carb's - ZX9R, R1 or similar...)
see this thread for more:
http://www.locostbuilders.co.uk/viewthread.php?tid=173359
[Edited on 14/8/2012 by mcerd1]
ryanill
| posted on 14/8/12 at 05:04 PM |
Ok so I looked at the facet pumps and the actual zx9r pumps looking at about £80 for facet set up and between £50 and£100 for bike pump depending on
seller is the pressure regulator needed if I still keep my return to tank system? And with the bike plumb still supply enough fule with the carbs
running the bigger cylinders ( but derematiclylower rpm)
cheers guys
mcerd1
| posted on 14/8/12 at 08:20 PM |
yes you need a regulator if you use a facet type pump - the bike carb's really hate too much fuel pressure, thats why the bike pumps are self
regulating
(you really shouldn't have to pay more than £50 for a s/h pump - maybe even try Malc @ yorkshire engines)
the bike pump is fine for the size of engine, its actually the power thats important (if you think about it the choke size is the same as the bike
too)
a 1.0 bike engine at 14,000rpm vs 2.0 car engine at 7000rpm - bothproducing about the same power, so both need the same amount of air and fuel
