Krash67
| posted on 24/4/13 at 08:18 PM |
Zetec - ERA sump - oil pick up pipe
Hi all.
Recently got hold of a ERA shortened sump to go on my silver top. However need a shortened oil pick up pipe. Having at least two stock ones to hand,
can anybody provide some guidance/ pictures/ dimensions of pipes that they have modified for there shortened sumps.
If your not fast..........your last!!!
femster87
| posted on 24/4/13 at 08:32 PM |
Did you get the baffle plate as well
macc man
| posted on 24/4/13 at 08:50 PM |
I chopped the zetec pipe and welded a pinto strainer on the end. Make sure the strainer does not hit the bottom of the sump. You need a bit of
clearance to allow it to suck the oil up. Had to do mine twice to get it right.
Krash67
| posted on 24/4/13 at 10:01 PM |
No, but gather that you only need that 3 sided baffle plate for blacktop 2 part sumps.
Krash67
| posted on 24/4/13 at 10:06 PM |
Why a pinto strainer?. Further googling , read that you need about 8mm gap between the Strainer and sump. Looks like need to raid the kids
plastercine.
redturner
| posted on 25/4/13 at 05:36 PM |
I bought an era sump with the plans to fit it on my Zetec but changed my mind and went dry sump. The filter/pick up/strainer as supplied by ERA is
only 3/4" deep and say 4" across and era adviced that it should be within 10mm. The strainer was produced by era. You just need to cut and
shut the pipe to fit as it is very difficult to bend.
JAMSTER
| posted on 25/4/13 at 06:52 PM |
any good might be worth a call
http://www.tigerracing.com/zencart/index.php?main_page=product_info&cPath=0&products_id=247
femster87
| posted on 26/4/13 at 11:32 AM |
I beleive because of oil surge, You need the baffle bolted on. Where abouts in scunthorpe are you? I have a spare plate that I did not use that you
can have.
Krash67
| posted on 27/4/13 at 07:45 AM |
Thanks for the help so far guys. Looking at Era oil pick up I'll see how I get on, might end up going here.
Femster 87- U2U sent
femster87
| posted on 28/4/13 at 07:55 PM |
I did not get the u2u
