nick-york
posted on 30/10/13 at 09:57 PM |
Is this fuel pipe ?
Hi ive just uploaded a picture of the label on some pipe i bought about a couple of years ago . Im trying to get the picture on this thread . Anyway i
bought this pipe at the same time and place as my brake pipe. I asked for brake pipe and fuel pipe . Brake pipe is fine but when i check what is
supposed to be the fuel pipe i notice there is no mention of fuel pipe on the label !!So have i been sold the wrong pipe ? Or is it iva ok ?Im a bit
confused about it ! cheers
adithorp
| posted on 30/10/13 at 10:04 PM |
If it's the kunifer picture in your archive then yes, it's OK for fuel and IVA.
http://jpsc.org.uk/forum/
nick-york
| posted on 30/10/13 at 10:10 PM |
Yes thats the one . Do you know why it doesnt say
its fuel pipe on the label ?
adithorp
| posted on 30/10/13 at 10:35 PM |
Probably because it's sold as brake pipe. You can also use 10mm copper pipe from the plumbing section at B&Q and that won't say fuel
pipe on it either.
nick-york
| posted on 30/10/13 at 10:59 PM |
pipe on it either.
Cheers ! I didnt want to start fitting it and end up taking it out again if it was the wrong type.So thought id better
check first .
loggyboy
| posted on 30/10/13 at 11:05 PM |
Always best to check!
Its the rubber hose the inspectors get funny about if it doesnt have the right markings.
Mistral Motorsport
adithorp
| posted on 31/10/13 at 08:38 AM |
The IVA inspector will want to see markings (or documentation) on any flexible pipe you use for fuel. So thats any rubber or plastic fuel supply,
return or tank breather lines, plus the fuel filler pipe. Thats because the fuel may effect/perish it. Be sure what you use is for the latest fuels
(there's a post somewhere about it).
That doesn't apply to hard lines and he'll just want to check it's properley secured to the chassis. There's no recommended
distance for the anchr points but most use the recommendation for looms, which is no more than 300mm between mounts.
They'll also check the hose clips on your flexi lines. Standard worm drive (Jubilee) clips will fail due to the radius being fixed where the
worm drive is; That creates two little pinches points where fuel can leak. You need specific fuel pipe clips... It's a common failure.
Sorry about the flipant reply yesterday... it was a long day.
stevio73
| posted on 1/11/13 at 12:12 AM |
Might I ask what the criteria is fo fuel pipe? Is regular silicon hose okay? Ie the blue stuff?
Quick as a flash...... Nothing happens!
ss1turbo
| posted on 1/12/13 at 09:06 AM |
Good God no!
Get proper fuel hose - IIRC needs to have printed or embossed on it the relevant standard (SAE J30Rxx where xx depends on if you're using
injection or carbs).
Long live RWD...
Paul Turner
| posted on 2/12/13 at 06:37 PM |
Its all here
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=153126
But beware, there is loads of cheap rubbish out there form well known suppliers.
I have replaced virtually all my flexible hoses with TFE hose from Think Automotive but the 2 pieces of rubber will get replaced every 3 years, that
is as long as its lasts from recent experience.
