Valtra
posted on 27/12/13 at 01:36 AM |
new rad
Merry Christmas all
Had a long running engine rebuild and Microsquirt conversion on my old Fiat Twin Cam . during my last entries on here I was having overheating
problems which I eventually traced to a blocked rad . After a few sessions with Sulphamic acid the car was finally running cool again (looking back it
had been getting hotter before the rebuild) but the acid had eaten too much and left pin holes in the rad I had been running a rad that matched
the engine from a 131 Supermirafiori however they are now very rare and I've been scouring the internet to find a rad that will roughly fit the
same space have the same size 35mm inlet/ outlets in roughly the same positions . eventualy come up with a Mazda 323 unit that is the closest but it
is mega thin at about 18mm . Now I know that Westies and several others use a humble Polo unit , I don't live in the tropics and my lightweight
car rarely stresses the engine and has good rad air through flow . Also I'm not pushing big power out (around 120 bhp ) so would this fairly low
capacity rad be adequate ?
cheers
"If it looks like it works and it feels like it works, then it works"
MadMaxx
| posted on 27/12/13 at 06:08 AM |
Hope this can help :
http://annunci.ebay.it/annunci/ricambi-e-accessori/agrigento-annunci-aragona/radiatore-valeo/58448810
britishtrident
| posted on 27/12/13 at 06:14 AM |
Copper-brass radiators can be re-cored, there are still a few radiator repair workshops around.
[/I]
Ben_Copeland
| posted on 27/12/13 at 08:12 AM |
Dont see why a polo rad wouldn't work they run much more powerful engines.
Just depends if the outlet positions suit your engine. You can also get alloy versions that are thicker. I've just fitted an alloy honda civic
racing radiator that thicker but then I'm running 250bhp turbo
[Edited on 27/12/13 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ragindave
| posted on 27/12/13 at 11:20 AM |
This one is good value and a larger core
http://www.ebay.co.uk/itm/121212199665?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Valtra
| posted on 27/12/13 at 11:29 AM |
Yes, been looking at civic units, as Polo is too wide for my narrow chassis . Civic has 28mm unions so needs some fiddling to step down from 35m fiat
Valtra
| posted on 27/12/13 at 11:30 AM |
Mine needs a new core and new header tank ......
Valtra
| posted on 27/12/13 at 11:38 AM |
Interesting but not sure how Ebay works in Italy doesn't look a familiar format
Ben_Copeland
| posted on 27/12/13 at 11:50 AM |
My civic radiator is 32mm inlet/outlet
Ben
Roadster
Valtra
| posted on 27/12/13 at 02:33 PM |
You are no doubt correct I've looked at too many , still it would need a good sleeve to fit tight , also the civic units don't seem to
have a tapped hole for a fan switch either, more complication
Valtra
| posted on 30/12/13 at 12:37 AM |
found a heavy duty version of the Mazda 323 unit that was fitted to the highest power Automatic version which has a double thickness core , correct
size inlet/outlet in roughly the right place and a drilling for a switch. even reasonably cheap from Mr -Auto at about £75 inc vat and carriage.
should be well up to the job.
baz-R
| posted on 1/1/14 at 04:56 PM |
have a look at a merc 190e manual no a/c 1800-2300cc all years
its compact and 2" thick
