xico_ze54
| posted on 3/5/14 at 01:27 AM |
sierra 5-speed gearbox not type 9?
hi all
as I know some of you are great connaisseurs of Ford Sierra mechanics, I would ask the following:
- today I saw a Sierra 2.0 CLX with DOHC engine with carburetor, but the strange thing (for me) was the 5-speed gearbox had the reverse gear not as
usual in type 9's (up & left) but right & down just bellow the 5th gear.
I ask: is that the type 9 with another gear configuration or it is another type of gearbox? if this last case, what gearbox is it?
thank you very much in advance.
Amadeu
http://www.viseudesign.com/Sevenesque-36.htm
snapper
| posted on 3/5/14 at 04:56 AM |
MT75
Cast ally fixed bellhousing found on 2.0L DOHC & 2.4V6
1st 3.89
2nd. 2.082
3rd. 1.342
4th. 1
5th. 0.822
[Edited on 3/5/14 by snapper]
I eat to survive
I drink to forget
Ben_Copeland
| posted on 3/5/14 at 05:39 AM |
As Snapper says mt75. Which is fine if you sticking with ford engine. Zetec etc
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
xico_ze54
| posted on 3/5/14 at 09:32 AM |
thank you both... but that bellhousing will match with what type of motors? all DOHC? all Zetec?
big_wasa
| posted on 3/5/14 at 10:12 AM |
Cvh, dohc, pinto, cosworth, zetec. Can be had in v6 format as well.
They have there advantages and dis advantages.
xico_ze54
| posted on 3/5/14 at 10:37 AM |
sorry for insistance... wich are the advantages and disadvantages?
snapper
| posted on 3/5/14 at 11:37 AM |
MT75 is stronger than Type 9
Bellhousing is fixed and box is bigger
Ratios are not as close as Type 9
May be better suited to 15" wheels and 3.62 diff
I eat to survive
I drink to forget
turnipfarmer
| posted on 3/5/14 at 11:54 AM |
As Snapper says, though a 3.92 diff is also used by many who run the MT75.
Bellhousing is integral rather than separate, & bolts straight up to a Zetec Blacktop (probably does the same with other Ford engines)
MT75 is wider than the type 9, but if you ditch the gearchange 'saddle', (as many do to fit a quickchange instead) it's actually
shorter than the type 9.
Here's a useful link... http://www.super7thheaven.co.uk/MT75_Gearbox
HTH
jacko
| posted on 3/5/14 at 03:05 PM |
mt75 are aluminium too as the type 9 are cast steel
jacko
big_wasa
| posted on 3/5/14 at 04:27 PM |
Much easier to remote mount the gear change aswell.
Paul Turner
| posted on 4/5/14 at 06:36 AM |
The main disadvantage of the MT75 is the lack of aftermarket gear kits.
The standard 1st gear in most production gear boxes is designed for towing a caravan up a gradient from a standing start by a car weighing over 1 1/2
tonnes. In most kit cars that is not the case and 1st gear just lights up the back tyres and you end up snatching 2nd shortly after moving off. By
simply changing 1st gear you end up with a much more drivable car and there are several suppliers who will do this with a type 9 for not much money,
you can even buy the kits and DIY if you know gearboxes and have the tools. As I understand it the only gearkits available for the MT75 are very
expensive Ford Motorsport ones.
Having owned 7's with standard ratios and ones with close ratios I know 100% which is best and for that reason alone I would never fit an MT75.
