daveb666
| posted on 28/5/14 at 04:50 AM |
Zetec Head Help
On him rpm gear changes I'm getting quite a serious puff of blue smoke. There is no obvious smoke under acceleration, just when I change
gear.
There's also nothing obvious if I coast down a hill either. The plugs are all oily too.
Various friends reckon stem seals or exhaust valve guides. I'm trying to get my hands on a zetec compression tester, but assuming my issue is
the head I'm after a bit of advice please.
I have a few options;
1 - Get my cylinder head reconditioned - £200
2 - Get my cylinder head reconditioned and flowed - £400
3 - Replace my silvertip head with a used blacktop head, but I'll have to meas around with pullies and not really know the condition- £200
4 - Fit an st170 head with vvt delete. This will mean an electric water pump and remap - £400ish
5 - fit an st170 head and retain the vvt. This will mean electric water pump, vvt controller and remap but should give very good gains - £500+?
Thoughts and opinions welcomed :-)
cliftyhanger
| posted on 28/5/14 at 05:59 AM |
New set of seals about a tenner or so? there are gizmos about (eg some thick string and I expect other higher tech ideas)so it can all be done in
situ. Guess the cam belt will have to come off though.
r1_pete
| posted on 28/5/14 at 06:42 AM |
You cannot put a blacktop or ST head on a silvertop block, they are different, silvertop - Hydraulic followers, Blacktop solid, so oilways are
completely different.
It could also be piston ring / bore wear.
Have you considered buying a complete Focus / Mondeo with a good engine you can drive & test, would probably work out cheaper than the recon
options....
daveb666
| posted on 28/5/14 at 08:30 AM |
Hi Pete, there are many many threads on passionford and turbosport where people are running silver top blocks with blacktop or st170 heads??
I'm not fitting an old engine, as I could end up in a similar position.
Dick
| posted on 28/5/14 at 09:41 AM |
You can fit a black top head onto a silver top engine, we have done this a few times. Have to mess about with the cambelt.
BaileyPerformance
| posted on 28/5/14 at 09:47 AM |
Check your breathers - you need one from the block, and one from the can cover, open to atmosphere (filters are a good plan)
r1_pete
| posted on 28/5/14 at 11:49 AM |
Wel thats my lesson for today.....
daveb666
| posted on 28/5/14 at 01:21 PM |
I have a camcover breather to a tank, although it was full LOL.
Where is the block breather please?
