matty h
| posted on 4/9/15 at 12:48 PM |
starter motor info
I am after a starter motor for an adaptor plate I have I believe it to be a ford one but it is 2 bolt and I can see the marks where it has been fitted
and have taken the sizes are there any websites that has sizes on so I can compare and identify the starter I need.
Thanks Matty
redturner
| posted on 4/9/15 at 06:59 PM |
Thanks Matty
Ford fitted lots of Lucas 2 bolt starter motors and the same one was used on the Mini as well . Dont have the part number to
hand.....
matty h
| posted on 4/9/15 at 07:49 PM |
It would great if you could find out the part number.
Regards Matty
redturner
| posted on 4/9/15 at 08:38 PM |
LRS something but will confirm tomorrow.....
matty h
| posted on 4/9/15 at 08:45 PM |
That would be great.
Thanks Matty
redturner
| posted on 4/9/15 at 08:47 PM |
Try LRS 102 (M35G) Lucas....
britishtrident
| posted on 5/9/15 at 09:46 AM |
If it is the standard Lucas bolt inertia mounting they came in 2 common sizes the smaller was used on smaller engines BMC A series Hillman Imp Ford
Anglia, Mk1 Cortina.. The larger was used on mid sized engines. Hillman Hunter & Avenger, BMC B series.
Ford switched to 3 bolt mounting on the Cortina about 1966 because the design on the 2 bolt mounting on the Ford gearbox didn't locate the
starter accurately enough to prevent jamming.
[Edited on 5/9/15 by britishtrident]
[/I]
redturner
| posted on 5/9/15 at 10:01 AM |
Ha ha, tell me about it and we finished up buggering about with 8, 9, 10 and even 11 toothed pinions to try to sort the problem, However the 2 bolt
and 3 bolt will fit the same bell housing.....
redturner
| posted on 5/9/15 at 01:36 PM |
Right, here we go. I have examined 2 starter motors, one 2 bolt and one 3 bolt, Both are M 35 G and the number on the box of the 2 bolt one is LRS
102. The spigots are the same size...I have tried both starter motors onto a bell housing and they both fit...............Makem sure that whatever you
fit that the tooth are pointing the right way as a pre engaged will have the lead on the flywheel teeth on the other side....
