sonic
| posted on 22/4/16 at 07:44 PM |
Anybody got a pinto engined car who can check the HT lead positions
Hi
As title, my 7 year old nephew decided to pull the spark plug lead out of the top of the dizzy and I have no idea which one goes where to put them
back in.... can one of you kind chaps have a look at yours and tell me which lead goes to which plug / cylinder please.
Thank you
Smoking Frog
| posted on 22/4/16 at 08:18 PM |
Sorry don't have a pinto but... Crank engine over by hand and get number one piston on the compression stroke (check with thumb over spark plug
hole). When the piston gets to TDC the rotor arm will be pointing to cylinder one contact in the distributor cap. The rest of the leads will follow
the firing order 1, 3, 4, 2 (I think) anti-clockwise. If you remember the rotor turns anti-clockwise at half of the engine revolutions the rest falls
into place.
edit
Old age is great but thinking again the rotor turns clockwise. Hopefully someone will confirm this!
[Edited on 22/4/16 by Smoking Frog]
LBMEFM
| posted on 22/4/16 at 09:31 PM |
Ford is 1,2,4,3 where as most others are 1,3,4,2.
Dingz
| posted on 22/4/16 at 10:04 PM |
Pinto is 1,3,4,2 : I think the crossflow is 1,2,4,3
went on and on.
theduck
| posted on 23/4/16 at 09:29 AM |
Pinto is 1-3-4-2
Turn engine by hand to line up the tdc marks on crank and can pulleys, pop the dizzy cap off, the the rotor is point nearest to is cylinder 1
