axle
| posted on 25/4/16 at 02:15 PM |
lightening fly wheel
Hi all
I am sure if this is been mentioned on the thread before or not, I am thinking of doing the above the car is running on EFI but do I need any other
modificatins . I am not going to be on the track.
Regards Axle
IVA passed 1st time thanks to the Forum members.
| posted on 25/4/16 at 02:53 PM |
Personally I'd be wary of doing it myself as a failed fly wheel could do some serious damage. Keep in mind where the gearbox is in a 7 type car
and how close you are sat to it.
snapper
| posted on 25/4/16 at 03:27 PM |
You should only remove the weight from the rear edge and not much
IMHO you can pickup a steel one of eBay for £70 or so, they are stronger and safer
I eat to survive
I drink to forget
theconrodkid
| posted on 25/4/16 at 03:39 PM |
as above,if not done properly they can explode and potentially take your leg off....think about that first
who cares who wins
pass the pork pies
axle
| posted on 25/4/16 at 03:48 PM |
Hi ALL
Sorry for any misunderstanding I would not even think about doing myself I have seen some horrible disaster when the fly wheel has snapped off cutting
through the bell housing so thanks for all your concerns.
What I was really asking:
a) is it really worth it if I am not going on the track?
b) is it really enough on its own?
Regards Axle
| posted on 25/4/16 at 05:42 PM |
Is it worth it?
You need to do cost vs performance gain for this and any other mods and decide on the numbers that come out.
| posted on 25/4/16 at 05:44 PM |
What engine? If a Zetec then the 1.8 flywheel is lighter than the 2 lt
axle
| posted on 25/4/16 at 08:10 PM |
Hi
Thanks for your reply
It is Ford 2L DOHC 8V running with fuel injection.
Regards Axle
mark chandler
| posted on 25/4/16 at 08:11 PM |
Absolutely worth it yes, it will not make a lot of difference in the high gears, it should transform 1st and second.
I started with a DMF and heavy 11" clutch it weighed in at 28kg, put in a solid flywheel with 9" clutch and 6 paddle driven plate, car now
spins up its rear wheels on acceleration in 1st, which it would never have done before.
I did take a fair bit of weight out of the cast wheel, not to everyone's taste, it was checked and balanced up by an expert.
Straight 6 so naturally balanced which helps.
This is why bikes Rev like fury!
axle
| posted on 25/4/16 at 08:19 PM |
Hi Mark
Thanks for the encouragement I do not intend to change the clutch ,as it is new and not sure if I can a get a lighter one , but should that matter?
[Edited on 25/4/16 by axle]
Regards Axle
Adamirish
| posted on 25/4/16 at 08:51 PM |
Personally I would just buy one that was designed to be light rather than lighten a standard flywheel. I once saw a supra at work with a machined
flywheel. It let go putting a hole in the (luckily) passenger footwell.
I do like the revvy nature of a really light and balanced flywheel. The flywheel in my Xflow weighs a measly 5kg's. It revs QUICKLY but still
very driveable.
MK Indy 1700 Xflow
axle
| posted on 25/4/16 at 09:16 PM |
thanks for the feed back
Regards Axle
mark chandler
| posted on 25/4/16 at 10:13 PM |
quote: Originally posted by axle
Hi Mark
It's a big spinning lump, you want to concentrate the weight as close to the middle as you can as it has less affect (further the weight from
the centre the more it has to move to accelerate it) hence fitting a smaller cover and driven plate provided it can handle the torque even if it
weighs the same however to spin up I s effectively less. I have a ceramic paddle driven plate as it can support the torque in a smaller package.
The next step up for me is a twin plate setup, again reducing the distance from the centre of a crank + lighter as well
Canada EH!
| posted on 26/4/16 at 12:46 AM |
You may find a light flywheel a pain in normal driving careful use of clutch and throttle while starting from stopped.
snapper
| posted on 26/4/16 at 06:13 AM |
Most light flywheels are fine for the road, only the really really light skeleton ones with a very lumpy cam are difficult on the road.
I fitted 2 steel 6Kg flys to Pinto's 1 with a lumpy cam.
Even with the lumpy cam I did not notice a down side but the engined revved better especially in low gears countering the off cam feel.
I eat to survive
I drink to forget
axle
| posted on 26/4/16 at 10:57 AM |
Thank u all for the replies!
Regards Axle
