dave_424
| posted on 25/1/17 at 10:04 AM |
Gen 1 busa rough running
Hi guys, got a problem with a gen 1 busa engine. The problem is that once the throttle is opened from idle, it miss fires and hangs at the same rpm
just like it has hit a rev limiter. If you open the throttle incredibly slowly, the rpms will rise like normal. But opening the throttle over 10%
makes it hit a rpm wall at that point.
Strange thing is, is that if you take the vac line off the map sensor (keeping the sensor electrically connected) , the engine runs perfectly, revs
freely and very responsive.
Have tried swapping ignition coils around, new set of spark plugs and tried another map sensor.
So what could removing the vac line to the sensor be doing to make it run perfect?
All advice would be much appreciated
Thankd
Dave
HPDxxx
| posted on 25/1/17 at 10:20 AM |
i think ECU read wrong air quantity.
there are two map sensor, one connected on vac lines, and another on free air.
are both connectec and work fine?
double check if there is some leaking pipe on vac.
dave_424
| posted on 25/1/17 at 02:55 PM |
I agree, will check the atmospheric pressure sensor. All vacuum pipes have been checked
Dave
dave_424
| posted on 9/2/17 at 07:09 PM |
We have tested the atmospheric sensor and seems to working. Resting at atmospheric pressure it shows approx 3.6v, applying pressure or vacuum makes
the vague change by around 2v, so seems okay
What else would be worth checking? Running out of possibilities at the moment
