Gre3D
| posted on 3/2/17 at 09:41 AM |
1.8 zetec flywheel part number
hi guys,
i need a 1.8 zetec flywheel for a 2l conversion in my locost.
i called the salvage yard but they dont have 1.8 engines, they do howevere have a large heap of flywheels...
is there anything specific about the 1.8 zetec flywheel or numbers cast into it so i can recognize the thing ?
[Edited on 3/2/17 by Gre3D]
chris
| posted on 3/2/17 at 10:48 AM |
i have one and a cct133 thrust bearing £80 for both if your interested plus postage
| posted on 3/2/17 at 10:53 AM |
Numbers depend on all sorts of things, year, factory, engine spec etc etc...
However they all look the same, like this...
Gre3D
| posted on 3/2/17 at 11:07 AM |
thx coozer! any pics of the rear face?
Myke 2463
| posted on 3/2/17 at 11:13 AM |
Just measured the thickness on an 1800 silvertop engine i have for sale if anybody is interested and it's 35mm near the ring gear if that helps.
Be Lucky Mike.
Gre3D
| posted on 3/2/17 at 12:05 PM |
thank you mike, could you perhaps post a picture of the rear face of the flywheel?
if i can't seem to find a flywheel at the scrapyard then you guys are my best option i think
| posted on 3/2/17 at 12:08 PM |
Here you go, good luck!
Gre3D
| posted on 3/2/17 at 12:53 PM |
thanks! you guys have been most helpfull,
while we're at it, any idea how many degree before TDC the missing tooth is?
SteveRST
| posted on 3/2/17 at 04:12 PM |
I have one if you want. £29 collected from KT9 1JN, or £45 posted.
| posted on 3/2/17 at 06:12 PM |
36-1 at 90degrees.
Gre3D
| posted on 3/2/17 at 06:54 PM |
Thx coozer. Remind me to buy you a couple of beers should i ever meet you 😃
Gre3D
| posted on 8/2/17 at 11:48 AM |
i manages to find a flywheel in the scrapyard, there was only one though.
the face of the flywheel needed some machining because it was f*cked up. probably been driving with a worn clutch and burning the whole thing. but
it's looking fresh as ever at the moment
