LBMEFM
| posted on 28/3/17 at 02:23 PM |
Citroen C4 engine fault
Just back from a short journey in my wifes C4 Citroen when the engine fault light came on. It displays the fault on the cars read out as
"antipollution fault" the engine runs rough and lacks power. Any ideas on what's happened please and how to fix it?
Thanks Barry
mcerd1
| posted on 28/3/17 at 02:33 PM |
What engine has it got ?
LBMEFM
| posted on 28/3/17 at 02:43 PM |
1600 petrol
| posted on 28/3/17 at 03:15 PM |
quote: Originally posted by LBMEFM
1600 petrol
And there was me expecting you to say diesel - in which case I'd say the diesel particulate filter and give it a good pasting to clear it.
ian locostzx9rc2
| posted on 28/3/17 at 03:43 PM |
It's got a misfire more than likely could be a lot of things coil pack ,spark plugs injectors wiring ecu and lots more you need to get looked at
as it will damage the cat .
wylliezx9r
| posted on 28/3/17 at 04:39 PM |
My money's on it being an EGR related fault.
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
George Best
obfripper
| posted on 28/3/17 at 05:04 PM |
Is it an ep6 engine?
If so, check the oil cap and dipstick are seated correctly, they run like a pig if the crankcase system can suck in air, and it may also make the
cooling fans run continually.
Dave
r1_pete
| posted on 28/3/17 at 05:29 PM |
Daughters did similar a few years ago, it was a stuck vtr valve, another symptom was when starting it sounded as though there was no compression.
We cleaned it and got it running well enough to trade in against a Fiesta.
adithorp
| posted on 28/3/17 at 08:04 PM |
Could be any one of hundreds of faults. You need a code read and work from there.... However from experience of how people describe faults and
balance of probability I'd pick coil pack.... But I wouldn't bet money on it.
http://jpsc.org.uk/forum/
LBMEFM
| posted on 28/3/17 at 08:52 PM |
Thanks for the replies, I'll have a look at it in the morning and let you no how I got on.
| posted on 29/3/17 at 07:50 PM |
A code reader should take some of the guests work out. Failing that drive away from home and call the AA man out, he will tell ya... presuming you
have break down cover...
