David Jenkins
| posted on 29/7/18 at 09:37 AM |
Replacing x-flow inlet manifold bolts (& stud)?
Lately I've been faffing around with carb swapping (the bike carbs are back on!) and I've found that the inlet manifold bolts and stud are
a real PITA. With the original manifold I couldn't get an ordinary socket properly onto the head of most of them, making the correct tightening
with a torque wrench really difficult. It's impossible to get my socket onto the nut that holds the underneath of the manifold at the centre,
and my socket doesn't have a particularly thick wall - I have to freestyle/guess that one with an open wrench.
I was wondering whether I could replace all the bolts with good-quality socket cap-head ones, probably with a flat washer underneath. I have a set of
1/2" sq. hex keys that might fit, or I could buy just one imperial-sized key for this job. Can anyone see any problems with this?
They're only tightened to 15-19 ft/lb, so super-grade steel bolts aren't required.
I was also wondering if I could replace the central stud with a bolt (I don't know the thread of the bit that goes into the head at this time)
to make life easier there too. This assumes that I could remove the stud without breaking it, which is always a significant risk - it would be a case
of "try to remove it gently, and give up if it won't yield easily".
DW100
| posted on 29/7/18 at 09:43 AM |
Yes is the simple answer.
It always used to be common practice on crossflow race engines.
If I remember correctly they are 5/16 UNC.
David Jenkins
| posted on 29/7/18 at 10:04 AM |
Thanks!
5/16" UNC sounds about right. Does that go for the stud as well?
DW100
| posted on 29/7/18 at 10:17 AM |
Yep used to replace all of them, inlet and exhaust manifold.
David Jenkins
| posted on 29/7/18 at 10:22 AM |
Not fussed on the exhaust side - they're easy to do.
David Jenkins
| posted on 29/7/18 at 10:27 AM |
Being excessively lazy this morning - can you remember what length they are?
snapper
| posted on 29/7/18 at 10:36 AM |
You need a longer socket with a large circular hole so stud goes through
I eat to survive
I drink to forget
David Jenkins
| posted on 29/7/18 at 10:46 AM |
Not as easy as that - the socket fouls the underneath of the original manifold, and the coolant pipe on the bike carb manifold.
[Edited on 29/7/18 by David Jenkins]
| posted on 29/7/18 at 11:29 AM |
If it's any help David I have a few spare heads that I can take the central stud out of and measure. My manifold is held on with normal bolts
apart from the central stud which as you say can be a pain . I will be changing the exhaust studs and nuts for socket head screws next time I have the
exhaust off for the same reason. If you have problems getting the replacement S/H screws let me know , there is a place in Linton that's very
helpful .
David Jenkins
| posted on 29/7/18 at 11:58 AM |
Thanks Mel
I should be OK - there's a first-class fastener supplier in Ipswich (Suffolk Fasteners) so I hope to
be able to get them there. They're also quite low-priced!
helpful .
David Jenkins
| posted on 29/7/18 at 12:50 PM |
Decided not to be lazy - they're 5/16" UNC x 1.25"
steve m
| posted on 29/7/18 at 09:11 PM |
What inlet manifolds are you using, as ive never had an issue, putting nuts and washers on either short or long tract twin 40 manifolds, nor the
28/36dcd manifold on my xflow,
Ive always used studs and nuts, as its easier to mount the manifold on a stud than a bolt, but at the very worst use studs on the furthest apart holes
to centralise the manifold, and possibly use bolts on the other three
steve
| posted on 29/7/18 at 09:31 PM |
In my case it's a homemade inlet manifold with fairly large ports using Kawasaki ZZR1100 throttle bodies , the exhaust is a bespoke large bore
manifold that doesn't have enough room to get a socket or ring spanner on the cEnter two nuts
redturner
| posted on 30/7/18 at 08:54 PM |
I have never ever had a problem fitting / removing the manifold nuts. I always use a 3/8" drive socket. I probably have 6 manifolds in the
garage and they all work just as good and nothing different in the castings.....
David Jenkins
| posted on 31/7/18 at 09:02 PM |
To be perfectly honest, I can just about cope with the 4 bolts that hold the manifold - it can be a struggle sometimes to get the socket on properly,
the extension bar often rubs against the manifold itself, and it can be a pain when doing things within the engine bay (the chassis gets in the way).
It's the centre nut-on-a-stud that's a pain - I can't get at it properly with a socket as the inlet pipe is quite close on my bike
carb manifold. Even if I used a long thin-walled socket, it wouldn't get over the chassis problem.
I will convert to socket cap head screws in the near future as access will be a whole lot easier all round. They're on order, and should arrive
tomorrow!
| posted on 31/7/18 at 09:15 PM |
I got mine today £4 for 15
