bikecarbfred
| posted on 27/3/19 at 06:39 AM |
rust in coolant - suitable flush required?
after rebuild noticed rust in coolant as the head and block were washed with water prior to build and left to dry which developed all orange within
them
everytime thermortat opens,, the water washes out the rust into coolant tank
im yet to use anti freeze. ive ordered 5 litres.
im also considering using thermocure 5 litres coolant flush for £22.00
anyone ever used thermocure?
ive drained all the rusty water out but obviously there wil be some still in engine block.
can been sat for three weeks, wondering what's likely hood it will eat the head gasket.
Bluemoon
| posted on 27/3/19 at 06:49 AM |
Citric acid flush... Cheap and works well..
bikecarbfred
| posted on 27/3/19 at 07:04 AM |
just bought some wynns rust rad flush, 3 bottles.
its a clean build so not wanting to take thermostat out and make a mess.
will use one bottles, warms engine up... , drain it. then go through other two bottles. warming engine up.
should be able to do it hopefully all in 30 minutes. just be careful not to burn hands.
| posted on 27/3/19 at 08:08 AM |
What do you expect just using water??
bikecarbfred
| posted on 27/3/19 at 08:44 AM |
i was told just to put water in on the first warm up on rebuild
40inches
| posted on 27/3/19 at 09:19 AM |
That's just to check for leaks, saves coolant if there is a leak.
If the system is leak free then it should be drained and refilled immediately.
djtom
| posted on 27/3/19 at 12:36 PM |
Citric acid works well. £5 worth of crystals from Amazon gives you enough to repeat several times. Fill up with water, dump a load of CA crystals into
the header tank, drive it until hot, drain it and flush through. Repeat if necessary, then flush through (I hooked it up to the garden hose until what
was coming out ran clear). Then fill with antifreeze.
Mr Whippy
| posted on 27/3/19 at 01:08 PM |
save your money, just flush it with the hose till it goes clear and then use antifreeze, it will be fine after that, change every 3 years
bikecarbfred
| posted on 27/3/19 at 07:08 PM |
i got worried this morning when i read on a forum it will destroy the headgasket.
panicking now until the flush arrives lol
gone through all th ehardwork of building an engine n something so trivial can bring it crashing down,
ive left the car sat in garage for 3 weeks since first warm up, hopefully thats not long enough to destroy the gasket.
Mr Whippy
| posted on 28/3/19 at 07:23 AM |
yeah water & rust really attacks mineral fibre and aluminium, it's like alien acid blood to it
