Author: Subject: zetec oil filter
andybod
posted on 8/2/05 at 07:17 PM Reply With Quote
zetec oil filter
finally managed to get engine (2.0 zetec) in place today only problem oil filter foul.s bottom column link i have read on here somewhere (but can,t find it know) of using a shorter oil filter any idea,s what they come off or part number,s thank,s
stevebubs
posted on 8/2/05 at 07:18 PM Reply With Quote
http://www.trustelectrical.co.uk/html/prices.htm
bob
posted on 8/2/05 at 07:33 PM Reply With Quote
Pop down to halfords you'll get two or three for the prices at trust,i've been told its a fiesta escort cvh filter thats shorter,champion part number is C104 and halford number is HOF 200.
I'm waiting confrimation that an even shorter renault filter will fit as well.
Big Stu
posted on 11/2/05 at 07:54 PM Reply With Quote
A fiesta Zetec oil filter fits and works well. The 1.25 Zetec. 1999.
andybod
posted on 11/2/05 at 08:42 PM Reply With Quote
thank,s tried a hof200 from halfraud,s still to big ordered a remote filter housing and adaptor plate to mount filter against chassis so i.ll still be able to use original filter will try renault filter though thank,s
givemethebighammer
posted on 11/2/05 at 09:49 PM Reply With Quote
Crossland 659 / Coopers 107X / FRAM PH2874 (really short one)
Crossland 573 (slightly longer one)
coopers Z25 (longer)
Halfords 221/Champion C115 (same as above?)
Halfords 265/Champion C148 (very long - recommended part)
I use the shortest one - Crossland 659
shaywez
posted on 12/2/05 at 08:40 PM Reply With Quote
filter
Champion C 104 is what i have fitted, plenty of room
bob
posted on 12/2/05 at 10:55 PM Reply With Quote
Chrisw informs me the renault 5 turbo filter goes on too
andybod
posted on 13/2/05 at 08:27 AM Reply With Quote
tried the halford,s hof200 which is the champion alternative and is about 25mm to long starting to wounder if engine is positioned correctly but it does sit in the centre of the chassis and gearbox mounting not twisting
shaywez
posted on 13/2/05 at 08:57 AM Reply With Quote
filter
Just got the box out that my filter came in and it is a Purolator L17603, it fits the following cars:Renault R4 GTL-6/84, R5 TL, GTL 1.1-6/84, R9 1.1-6/84 and the R11 1.1 6/84. Cost me £6.58 from local factor, this should fit easy with no problems.
britishtrident
posted on 13/2/05 at 08:59 AM Reply With Quote
AC-Delco had a range of universal oil filters for popular models that because of "advanced design" were much smaller externally that the normal fittment.
I don't know if they still make them.
givemethebighammer
posted on 13/2/05 at 11:36 PM Reply With Quote
whatever you buy, get one with a bypass valve in it. (You can see the spring inside the oil filter). It might save your engine from damage.
see here:
http://www.yft.org/tex_vfr/tech/filters.htm
mad4x4
posted on 11/6/06 at 08:55 PM Reply With Quote
Can anyone post a photo of the filter Crossland 659 in place. And tell me the length of the 659 filter.
Scot's do it better in Kilts.
mad4x4
posted on 11/6/06 at 09:07 PM Reply With Quote
Danozeman
posted on 12/6/06 at 09:14 PM Reply With Quote
Christ this has been resurrected from early 2005!!
Dan
